TOP 10 common pilot errors
123456789Next >
551049 350 2015-11-18
DJI-Tim
We found out many RMA cases we have worked on in DJI was caused by pilot’s error
Analyzing the flight data or so called black-boxes we listed top 10 as below:
1.       CSC in the mid-air (Combination Stick Command)
The newbies favorite way to crash the drone by pulling the sticks to the down inner corners \ / or outside corners / \ and stop the motors
Solution: Never do this movements on a sticks while in the mid-air, unless in case of emergency
2.       Propeller shoots off
Of course the self-tightening props is a great invention of humanity, but some of the users only slightly push it till it stops to turn and think that it’s enough, which brings aircraft to shoot the props off on a high RPM
Solution: Never let the propellers loose on a motor. No matter if you are using self-tightening props or quick release props, always make sure that every propeller sits tight on a motor before taking off.
3.       RTH Crash
You shooting the beautiful building (tree, hill, tower etc.), and flying behind it for the better shot, suddenly you lose the RC signal, because the building got on the way between the aircraft and the remote controller. So automatic go-home function turns on and your aircraft crashes into that building on a way back home.
Solution: Set your return to home altitude higher than any obstacles (trees, buildings etc.) in your area.
MC settings> Advanced Settings> Failsafe mode
4.       Auto landing far from home
Once your aircraft is out power, you will get low battery warning and 10 seconds to cancel the RTH. After canceling the RTH you still can keep flying, but once your battery will hit the critical battery level, aircraft will start auto-landing. Pilot cannot cancel the landing, but the roll, pitch and yaw are still controllable.   That’s a good luck if it lands on an opened spot, but if there is a trees or water… you know…
Solution: Go back home straight after low battery warning, don’t force your drone to fly till it’s totally out of power.
5.       Flying out of sight
Flying out of sight is pretty dangerous, because all you can see is the video from the aircraft, which limits your view of the environment and can bring pilot to the altitude or direction misjudgment. Also it raises the chances to crash into the objects hard to see through the FPV, such as power lines.
Solution: Do not fly out of the sight if you are not familiar with flight environment.
6.       Watching FPV and flying backwards
Everyone likes to do some beautiful shoots like this, but flying backwards we don’t see the way aircraft is moving to, so it’s extremely easy to crash your drone into the other objects on the way.  It’s like walking backwards without watching the way.
Solution: Do not stare at the screen all the time, watch your aircraft and flight environment.
7.       Indoor flight
Very often flying indoors due to the low GPS signal aircraft can drift, so it is getting difficult for the non-experienced pilot to control it.
Solution: Exercise your ATTI mode flight skills outside, to get the proper feeling of how to fly the aircraft without GPS
8.       Failsafe and gain the altitude
As all we know, when the aircraft is out of the 20 meters radius from home point in case of low battery level, it will ascend to the failsafe RTH altitude and then go home. So some of the pilots are getting the low battery warning and go land their aircraft manually without canceling RTH. But since the aircraft is out of the 20m radius from thehome point, at that very moment before drone touches the ground it lifts up automatically to the failsafe RTH height, and flies to the home point. This makes a lot of pilots’ panic, so some of them start to do some odd stuff like CSC, and eventually crash their drones.
Also, aircraft can hit the obstacle above it, such as (tree branches, roofs etc.) while automatically raising up.
Solution: 1. Keep calm, your aircraft is not flying away
                2. Land close to the home point
                3. Cancel the low battery RTH andland manually.
9.       Bad environment
Well, the bad environment is a reason of the huge part of the crashes.
What is bad environment? Metropolis full of skyscrapers or any surrounding of the high buildings, Power stations,TV stations, Mobile towers, high voltage lines, any sources of signal or electromagnetic interference.
Solution: Fly in an opened space, far from the buildings, power line towers and all those places described above.
10.   Braking distance
Flying aircraft at the full speed is a great feeling, but sometimes you can meet obstacles on a way, that you can crash in just because it’s too late to brake.
Solution: Same as a car, aircraft has its own braking distance, so keep it in mind. It’s better to start soft braking earlier than make an emergency stop with a risk of crash.
Be aware and fly safe!
2015-11-18
RichJ53
Flight distance : 1837356 ft
Nice logical information Tim
Written in a prefect way for all of us to understand....
Rich
2015-11-18
daniel.huang
Flight distance : 233 ft
nice one , Tim
2015-11-18
DJI-Tim
RichJ53 Posted at 2015-11-19 13:11
Thank you, Rich!  I was trying to be simple{:3_52:}
2015-11-18
DJI-Tim
Thanks, Daniel.  We hope our pilots do not repeat the mistakes of others!
2015-11-18
MJones
Flight distance : 74783 ft
Tim, by your sharing Your analysis OF ACTUAL DJI CRASH DATA, you have potentially saved many people thousands of dollars in lost equipment and bad press for both DJI and UAS globally.  It is more than simply logical advice, it is raising the operational awareness of a fledgling industry based on fact.  This analysis should be part of EVERY commercial UAS training course, and should be sticky number 1 for all new UAS pilots flying the Inspire 1 or other aircraft with similar characteristics and functionality.
WELL DONE TIM and thank you and DJI for sharing this information.
2015-11-19
gil
Flight distance : 1379308 ft
Hmmm, the graphic you pick to accompany the thread is a photo of a Phantom with the top off and a pair of tweezers ominously hovering above the main board.  Are you implying that futzing with your Phantom is a common error?
2015-11-19
KaiserSoze9
Flight distance : 35365551 ft
Thanks, very useful reminder.
2015-11-19
multirotorrd.co
Flight distance : 6176932 ft
Dominican Republic
Excellent compilation Tim  thanks
2015-11-19
Richardrambone
Flight distance : 298100 ft
DJI-Tim Posted at 2015-11-19 01:15
So your saying we're simple minded?
2015-11-19
aburkefl
Flight distance : 78612 ft
Awesome - using the actual flight data, you have confirmed many of my personal opinions!
Glad to see you guys posted that.
I wonder how many crashes resulted from the CSC maneuver with the pilot claiming he/she did no such thing?
Art - N4PJ
Leesburg, FL
2015-11-19
HFI
Flight distance : 904990 ft
Me likey things simple ; )
I think the above list (in bold on a separate sheet of paper) should be included with all DJI drone/UAVs purchased
2015-11-19
Swedrone
Flight distance : 14066975 ft
Sweden
Never heard of a mid air CSC, for me that is an urban legend
2015-11-19
DJI-Dave
Swedrone Posted at 2015-11-19 06:03
I have heard of at least three guys openly admitting to it on this form and on RC groups.
2015-11-19
Bartone
Flight distance : 53458 ft
Then there's always 'An Eagle Ate My Phantom!'
2015-11-19
Quadular
Flight distance : 14682 ft
Thanks Tim, very good info
2015-11-19
Rnfaust
Flight distance : 734938 ft
Thanks Tim for sharing with us.
I have actually performed 2 of the pilot errors myself. Now I won't have to perform the other 8!
2015-11-19
Movin on
Flight distance : 173455 ft
WELL DONE TIM  Thank you and DJI for sharing this information.
I hope you will, or have, posted on the Facebook page as well.
Keep up the good work!
2015-11-19
rodger
Flight distance : 20145135 ft
Great stuff Tim. I printed a copy for my Phantom 3 Pro Manual.
I have stated in the past that any problem that I have had, which are very few and that I was the cause of the issue.
2015-11-19
DJI-Dave
Bartone Posted at 2015-11-19 08:54
Yeah, that video was amazing!!! I could not believe how the Eagle just snatched it out of the air like that!!!
2015-11-19
DJI-Dave
Here you go.
Common Pilot error #11.
11. Flying near Eagles.
Solution: Do not fly near Eagles.
2015-11-19
Phantom Help
Flight distance : 228255 ft
Are those in a random order or is a CSC really the most common problem?
2015-11-19
nilsblix
Flight distance : 23047543 ft
Thanks for sharing - nice to know.
Done one of them (luckily with good outcome) - 9 left
2015-11-19
Grimtheviking
Flight distance : 11796312 ft
Well put together,
Thanks Tim.
2015-11-19
rosabertina
Flight distance : 854567 ft
Slovenia
great informations ;) thx
2015-11-19
ecriscit
thanks for the information, new to drones
2015-11-19
Sir Shepherd
DJI-Dave Posted at 2015-11-20 03:58
Here you go.
Gorgeous video DJI-Dave. Makes you feel that you are sitting right there in the inspire 1.
2015-11-19
Overmind
Flight distance : 595538 ft
Good info...thanks!
2015-11-19
DJI.Terry
Bartone Posted at 2015-11-20 00:54
LOL. I've seen two.
2015-11-19
DJI-Dave
Sir Shepherd Posted at 2015-11-19 17:41
It is.  Just so you know it is not my video and it is not an I1. It was a P3.
Dave
2015-11-19
DJI.Terry
Richardrambone Posted at 2015-11-19 20:08
Of course not  Pls focus on the technical side.
2015-11-19
RichJ53
DJI-Dave Posted at 2015-11-19 11:58
Here you go.
I was hired to fly the BLM  in my full size helicopter to have them count Bald eagles (big bird)  you cannot get close to the nests or the birds... ( at least 300 feet)  they do not like the sound of spinning blades.  They will bring down a full size aircraft
Rich
2015-11-19
Sir Shepherd
Still a beautiful video shot! I like it...
2015-11-19
ianwood
Flight distance : 5236 ft
Bad compass calibration should be at the top of your list:
http://www.phantompilots.com/thr ... plete-primer.32829/
2015-11-19
DJI-Dave
Sir Shepherd Posted at 2015-11-19 19:05
Yes me too.
2015-11-19
SightFlight
Flight distance : 1909078 ft
This is what every DJI owner wants, and needs, to hear. read and know. Fact based knowledge of ownership.   Thank You.
2015-11-19
adeluisa
Flight distance : 8235 ft
Thanks Tim.
Why DJI don´t change the csc stop motors procedure to one more improbable system because the joystick way is quite dangerous system and quite probable mistake. I suggest to  push c1 c2 and play shot button  at the same time.
2015-11-20
vamsyjosh
Flight distance : 4346220 ft
India
Thanks for your great information...... Mr.Tim
2015-11-20
VMAdigital
Flight distance : 851791 ft
Greece
USEFUL TIPS Tim. Basic for everyone !!! Thanks for this.
2015-11-20
Tharg (from the
Flight distance : 120784 ft
ianwood Posted at 2015-11-20 03:45
http://www.phantompilots.com/threads/com ...
Couldnt agree more!
People calibraring their compass before every single flight and introducing a bad calbration. Then, once airborne, they see the aircraft going into TBE and panic!
2015-11-20
123456789Next >
