It doesn't fly straight
3191 14 2015-12-1
Darkfito
Hi!
I have a phantom 3 Advanced with two problems ( Only sometimes, 2 or 4 times per flight and that's bad)
-First problem: It doesn't fly straight, twisted to the left.
-Second problem: The gimbal horizon is not straight. ( I think this is caused by the first problem since it only occurs when the phantom doesn't fly straight)
I experience this from the firmware 1.3.2, and I have never damaged my phantom or crashed.
I now use, firmware 1.5.30 y Rc 1.5.70  y app 2.4.2  y uso iPad mini 4.
I have made calibrations IMU (cold), gimbal, compass, stick Rc many times and solves nothing.)
Attached LOG (in the first few seconds try to fly straight and looks like twists only) (not fly in a straight line, a few seconds then recovers and fly straight back)
Attached VIDEO ( in the first seconds the gimbal not compensate. Later the phantom flies straight and make good again)
That's horrible and very sad
Thank you!
2015-12-1
mark.barbieri
Sounds like the exact same problem I'm having also and I've done all the steps you've mentioned. Hopefully somebody will chime in to help get this resolved.
2015-12-6
Darkfito
mark.barbieri Posted at 2015-12-7 08:05
Sounds like the exact same problem I'm having also and I've done all the steps you've mentioned. Ho ...
Hi,
We are many with this problem and DJI does not solve the problem
2015-12-7
Darkfito
2015-12-10
DJI-Patrick
Darkfito Posted at 2015-12-10 19:35
https://www.youtube.com/watch?v=9OJg-0yvV-A
Hi ,
Sorry but I can hardly decide whether it's a  aircraft tilt or gimbal tilt or both of them from the video . If you can't get this solved by all these calibrations you've done . Please send it to Germany support center .
2015-12-10
Darkfito
DJI-Patrick Posted at 2015-12-11 15:40
Hi ,
Sorry but I can hardly decide whether it's a  aircraft tilt or gimbal tilt or both of them f ...
Hi Patrick,
Thanks for answering.
Also I have cracks in the rear arms. What can be the problem the cracks?
It derived only when going forward (Phantom and gimbal). No drift when this static in the sky
Can you fix my dealer? (The send are € 100 plus many months without him)
Thank you!
2015-12-11
DJI-Patrick
Darkfito Posted at 2015-12-11 17:25
Hi Patrick,
Please contact support center as the page shows : http://www.dji.com/support?www=v1
2015-12-11
bobasbury
Flight distance : 1140502 ft
That video kinda looks like the gimbal is in FPV mode.
2015-12-11
bobasbury
Hi ,
Also, I would try changing all my camera, RC, gimbal settings back to the factory defaults.  Maybe on got changed by accident or ethereally.
2015-12-11
Darkfito
bobasbury Posted at 2015-12-11 19:43
Hi!!
The gimbal this mode follow. I have changed several times, but the problem continues.
The problem is from the firmware update 1.3.2
2015-12-11
DJI-Patrick
bobasbury Posted at 2015-12-11 19:44
Also, I would try changing all my camera, RC, gimbal settings back to the factory defaults.  Maybe ...
Worth trying !
2015-12-11
Darkfito
Can you see the clearest problem??
2015-12-14
DJI-Patrick
Darkfito Posted at 2015-12-14 19:09
Please contact dealers or support center for analysis . Thank you !
2015-12-14
Darkfito
DJI-Patrick Posted at 2015-12-14 20:09
My dealer gave me a housing and I've changed very carefully.
I disassembled piece by piece and I've cleaned up. I clean the gimbal axes...checking them.
Now the phantom flies straight and the horizon is straight.
Thx
2016-1-5
DJI-Patrick
Darkfito Posted at 2016-1-6 00:41
I disassembled piece by piece and I'v ...
Very glad to hear that !
2016-1-5
