Inspire 1 new firmware: X3 camera is now compatible with Osmo handle!
5569 11 2015-12-7
DJI-Amy
Overview:
1. All-in-One Firmware version updated to v1.5.0.30.
2. DJI GO app iOS version updated to v2.4.2.
3. DJI GO app Android version updated to v2.4.2.
What’s New:
1. Fixed battery level fluctuation issue.
2. The X3 gimbal on the Inspire 1 is now compatible with the Osmo. Note that you must attach X3
gimbal to the Inspire 1 before updating the firmware. Do not attach X3 gimbal to the Osmo to update
the firmware.
3. Follow Me feature now supported in Intelligent Flight Mode.
4. Optimized HDR performance.
5. Adjusted video storage rate to 60 Mbps at 1080p60, and 40 Mbps at 1080p30.
6. Added a feature to smooth the pitch, roll and yaw movement of the X3 gimbal from the DJI GO app.
7. Enforced read-only access for the data in the flight recorder.
8. Optimized sampling methods for the Vision Position System to improve its stability.
Notes:
1. Hibernation and gimbal protection is not supported on the Inspire 1 X3 gimbal.
2. Battery firmware is included in this All-in-One firmware update. Update all Intelligent Flight
Batteries by using this firmware.
3. The firmware can only be downgraded to v1.4.10 or later.
4. Calibrate the Inspire 1 X3 gimbal when using it on the Osmo for the first time.
5. Only use Inspire 1 aircraft to update the Inspire 1 X3 gimbal. Do not use this firmware to update the
Osmo gimbal.
2015-12-7
juansantiuste
¿Will the I1 X3 record in 120 fps as the Osmo X3? ¿Any diferences in the working of both cameras?
2015-12-8
DJI-Amy
juansantiuste Posted at 2015-12-8 16:05
Well, if you mount the X3 camera on Osmo, it will have all of the functions of OSMO except for the hibernation and gimbal  lock protection. If your mount to X3 back to Inspire 1, it will be just a X3 camera like before.
2015-12-8
arnohk
What about the storage rate of 1080p50?
Thanks in advance.
2015-12-8
DJI-Amy
arnohk Posted at 2015-12-8 20:17
Thanks in advance.
The storage rate of 1080P 50 is about 40Mbps.
2015-12-8
aadoat
Flight distance : 3113757 ft
Will osmo camera gimbal work with inspire 1?
2015-12-23
DJI-Amy
aadoat Posted at 2015-12-24 07:20
Sorry, the Osmo camera can't be used on inspire 1. Instead, the X3 camera with inspire 1 can be used on the Osmo after the latest inspire 1 firmware update.
2015-12-23
peroivind
Norway
DJI-Amy Posted at 2015-12-24 04:10
Sorry, the Osmo camera can't be used on inspire 1. Instead, the X3 camera with inspire 1 can be us ...
Would you happen to know if there is a slight chance of that the Osmo X3 ever might be compatibel to use on the Inspire 1? I have received a little scratch (Darn It!) on my Inspire 1-X3 lens, and don't really want to spend a huge amount of money on a completely new I1-X3 camera, if there is a slight possibility that I can use my Osmo X3 on the Inspire. Alternatively, are you considering selling spare parts for the X3 in near future?
(I am aware of the difference in focus etc. but I can't imagine that it would be totally impossible to make a somewhat usable video from the Osmo X3 from air?).
2015-12-25
DJI-Amy
peroivind Posted at 2015-12-25 16:46
Would you happen to know if there is a slight chance of that the Osmo X3 ever might be compatibel  ...
The Osmo camera can't be used on Inspire 1, most Inspire 1 users have X3 camera, that's why we make it compatible with Osmo handle, in the revert way, I am afraid the R&D won't develop this firmware considering the needs and complexity tradeoff. I am really sorry for your X3 lens scratch, please contact technical support for repair.
2015-12-28
pandastick
Brazil
DJI-Amy Posted at 2015-12-28 16:46
The Osmo camera can't be used on Inspire 1, most Inspire 1 users have X3 camera, that's why we mak ...
Hi Amy,
Is there any way to update the X3 without the Inspire drone?
I'm afraid my drone is broken but the X3 is functioning well - I am however unable to use it with the OSMO handle - the image is not passing through.
Thanks,
P
2016-4-25
DJI-Adela
pandastick Posted at 2016-4-25 23:26
Hi Amy,
Hello!
I'm afraid you have to upgrade the white X3 camera on Inspire 1 with the latest Inspire 1 firmware if you wanna use it on the Osmo handle.
You may borrow another Inspire 1 body or you may contact your dealer for help?
If your drone has any problem, please contact your dealer or our technical support for repair.
Thanks!
2016-4-25
BO$$MAN1
Flight distance : 2131886 ft
I own an Inspire 1 pro X5 and was looking to get an OSMO and ws wondering if the OSMO's X3 will work on my Inspire 1.  If you ask why would I want to do that, my X5 is in repair and I need a backup solution.  Also if I were to buy an Inspire 1 X3 could I put that on an OSMO?
Thank you
2016-7-4
