Lightbridge.Samsung Galaxy s5
2611 6 2014-12-29
gregsp71
I have been using a Lightbridge with Ipad but I now want to use my Galaxy S5 but cant get video or OSD.(Connection broken) Is this phone compatible?
2014-12-29
mark97564
Flight distance : 2067749 ft
How are you using light bridge with an iPad?
2014-12-31
mark97564
Try using usb  2.0 cord that comes with lightbridge or a different cable it would not work on my note 3 when I used the sub 3.0 cable that came with the phone..  Also you have to enable the developer options in s5's settings and then select developer options and turn on the usb debugging option and then plug it into lightbridge and approve debugging access that pops up on the task bar..  Next time my friend stops by I will use her s5 and see what I've gotta do to make it work with lightbridge if these tips don't help you..  She will be by tomorrow sometime so I will check back here to see your response
2014-12-31
Blade_Strike
Flight distance : 872694 ft
Any android device needs debugging turned on. I have verified it works on s3 and above.. Note 2-4. Best device is the ipad air imho. Super smooth on all transmission modes.
2015-1-1
hhackbarth
Flight distance : 375761 ft
I am using the LB ground system with a Galaxy S5. The option to activate developer mode and USB debugging is automatically opened when the LB app is started. Works perfectly fine and smooth on the S5 !
2015-1-1
gregsp71
mark97564@gmail Posted at 2015-1-1 11:41
ios app from here. http://www.dji.com/product/dji-lightbridge/download
2015-1-2
gregsp71
mark97564@gmail Posted at 2015-1-1 11:53
Try using usb  2.0 cord that comes with lightbridge or a different cable it would not work on my not ...
Thanks. Its now working. Sorted itself out in the end.
2015-1-2
