Topviewpics
Flight distance : 623232 ft
To everyone who are experiencing vibrations, this morning I decided to run an in-depth GAINS change and after 20min. into going up/down with the bird I finally go to something. First my specs
1 - Original Shell (1st Gen)
2 - Original motors, from first batch
3 - Original MC and ESC from first batch
4 - Firmware 1.6 on all components and batteries
5 - Latest GO app, on iPhone 6
6 - 46 degrees outside temperature
7- 9 mph winds
TEST 1 - Reduced Yaw to 95%
Result: Same vibrations as before with default
TEST 2 - Reduced Yaw to 90%
TEST 3 - Reduced Yaw to 85%
TEST 4 - Reduced Yaw to 80%
Result: Minor reduction, but not much better as before with default. Motor noise still there, different noise than when I flew with FW version 1.4
TEST 5 - Reduced Yaw to 80%, Reduced ROLL and PITCH to 90%
Result: I can say that it took off, sounded and behaved like when it had FW 1.4 on it. This did the trick so for those saying that ROLL + PITCH won;t affect it is not true
After reading this post for 1 hr. I can say that something changed on the FW that requires us users to tweak down the gains in order to maintain same smooth characteristics of FW 1.4. I have to say that now I have confidence to fly over water again.
Hope it helps. In sum, my gains are now as: 90, 90, 80, 100
Safe flights! |
