X5 very bad video!
2476 18 2016-1-8
mechanicus
Flight distance : 21086 ft
Does anybody experiance the issue I have with the X5.
I get a lot of noise and very unstable video.
Both DJI app (ipad) and X5 (mini sd) captured the same.
I'm guessing I have a bad camera.
DJI response please?
This is the clip captured with the DJI app on my Ipad
And this is the clip captured on the mini sd in the X5
2016-1-8
DJI-Ken
Flight distance : 1515312 ft
Have you done all the calibrations, including gimbal calibrations? and also adjust exposure, ISO, Shutter Speed, ?The X5 is a complex camera and not for beginners, fi you Google DJI X5 camera setting, or camera solutions, you will find a lot of information out there. I have not had a chance to fly a X5 yet so I am not very familial with all of it's settings.
2016-1-8
Sir Shepherd
Looks horrible! I'm not camera expert but seeing is believing!
2016-1-8
ge0se
Flight distance : 3184721 ft
Don't use D-Log video mode yet, it's completely messed up at this time, best one to use for now is Classic mode. Drop sharpness to -1 or -2 and use auto white balance for the time being as manual mode is broken. Also, set ISO to 200 or higher as 100 introduces horrible artifacts you're seeing.
2016-1-9
j_louey
Flight distance : 623743 ft
I have the exact result. I tried Cine mode and it was washed out and very unclear. I trued it in good lighting and normal color mode today and the result is the same. blurry and unsharp. I can use DaVinci todo the sharpening but it's still not good. I have seen it in much better quality before in previous versions of the firmware.
I took a couple of photos to check. They seemed much better.
2016-1-9
mechanicus
ge0se Posted at 2016-1-9 09:24
Don't use D-Log video mode yet, it's completely messed up at this time, best one to use for now is C ...
Thank you so much for this info!
2016-1-9
dopeytree
Flight distance : 6716467 ft
Also check your firmware. I think my first out the box flight had this flickering. The gimbal looks fine. I try to shoot in manual at 50 shutter / iso 100 & then change the aperture to suit the scene but usually around f5.6 sometimes f8 / f10. it depends how sunny it is.
2016-1-9
Artiks
Flight distance : 979964 ft
Portugal
Hi mechanicus,
Well i'm not an expert, I would follow DJI Ken instructions but that doesn't seem to be (in my opinion) a problem of settings. The footage is a bit odd i guess (even for my x3 that have lower quality than your x5).
I hope you find the solution.
Cheers!
2016-1-9
Alastair
Flight distance : 96631 ft
Just an aside, I noticed that there is a flickering in the lower half of the frame.  I had this issue with my x3 (though not as bad as yours) and DJI replaced the camera...bad sensor.
2016-1-9
nilsblix
Flight distance : 23047543 ft
mechanicus Posted at 2016-1-9 17:37
You think when you pay a lot more you buy a better product...   ...
Your examples is so bad that it is not just the D-Log issue you se on you video. There must be something else ? Do you know your settings on the shoot ?
2016-1-9
Machoman
Flight distance : 1036959 ft
Austria
Isnt that the flickering problem they said is solved in Fw 1.5 ??
2016-1-10
mechanicus
Alastair Posted at 2016-1-9 16:50
Just an aside, I noticed that there is a flickering in the lower half of the frame.  I had this issu ...
I am afraid of that as well.
2016-1-10
mechanicus
nilsblix@gmail. Posted at 2016-1-10 01:00
Your examples is so bad that it is not just the D-Log issue you se on you video. There must be som ...
If I remember correct:
Iso 100
Auto wb
D-log
1.6/?
2016-1-10
DJI-Tim
ohh.. that is pretty bad video. Did you just get the camera like this, or before it was ok?
2016-1-11
mechanicus
DJI-Tim Posted at 2016-1-11 09:32
I did not shoot that much yet.
I am afraid it could be the cam. I have a lot of noise now and then. Could it be settings or fw?
2016-1-11
DJI-Tim
mechanicus Posted at 2016-1-11 17:08
I am afraid it could be the cam. I have a lot of noise now and then ...
even in a Auto mode it is not suppose to be like that... I'm afraid your camera has some problems, please contact your dealer about it
2016-1-11
Starship
mechanicus Posted at 2016-1-10 07:47
Iso 100
That didn't look like ISO 100 .... to me it looked like 800 or higher.  The grain looked like ISO grain.  Also you had auto WB set, and then partially flew into the sun at either dusk or sunset.  Even my Canon 1D mk3 struggles with that.  And I've seen auto WB cause a sort of flickering effect when the sun pops in and out behind things, and reflections.
Before you get upset with the camera, try it in a more photogenic environment.   Like say, a cloudless, or partially cloudy day, mid morning or mid afternoon.  Make sure you manually set WB to match the light, and ISO to 100.  Put in -1 sharpness, that will help with the jaggies on things like straight edges (power lines, and shingles).
And another note on flickering........ you did raise your landing gear, didn't you?   Some people, starting out, are leary of raising the gear.... "JUST IN CASE"
2016-1-11
domidragon90
Switzerland
Looks like too high iso in combination with the bad firmware. Hope DJI is fixing the problems soon!
2016-1-14
R&L Aerial
Flight distance : 298100 ft
Omg it looks like you have an old flip cell phone camera strap on the front, i dont think all the calibration in the worlds going to help.
2016-1-15
