Ronin-M What is "Push mode"?
8770 4 2016-1-15
valealvarez.s96
Argentina
I have the ronin-M and i resently updated it to new firmware, there is a new feature called "push mode", and i dont know what it does, does it means you can readjust camera balance without turning it off?
2016-1-15
DJI-Tim
Ronin-M Push Mode allows the tilt and pan axes to be adjusted directly by hand while the Ronin-M is turned on. This function can be enabled in the DJI Assistant app or PC/MAC Assistant.
Do not adjust the gimbal by hand too frequently when Push Mode is enabled, or else the motors may overheat and enter Overheating Protection Mode, at which point a manual restart is required.
This feature is available with Ronin-M IMU firmware v1.4, GCU firmware v1.2.
2016-1-27
Flying Andy
Flight distance : 328786 ft
Hallo,  after change the camera i use normally with a lightest one (Sony Alpha 6500 with 18-105 mm lens) the manu push mode seems not wotking anymore (all relative functions are remained always on the app)...Everytime i try to correct it by hand, it return at the startin position, what could be? With the previous camera (more weight) was working correctly...thx, Andy
2017-6-28
DJI-Jamie
Flight distance : 112405 ft
Flying Andy Posted at 2017-6-28 12:52
Have you tried setting the Ronin back to factory defaults and setting it up again?
2017-6-29
JacoboCastro
Colombia
I Can´t turn on the manual adjustment in the push mode menu. why?
2017-12-16
