Orientation icon lower left
844 4 2016-1-19
MJones
Flight distance : 74783 ft
If the controller (iPad) and the aircraft are pointed in the same direction (forward), should the red arrow in the orientation area lower left be pointed exactly up?  I had not noticed this before (maybe it was the same) but mine is pointing about 20 degrees off.  In other words, if I turn the aircraft until the arrow points up and turn my controller to exactly face the aircraft, the arrow moves about 20 degrees.
I recalibrated the compass with no change.  Maybe I misunderstand the function of this arrow but don't remember this offset before 2.5.1. I have already deleted and re-installed the app.  Any explanation or suggestions appreciated.
Regards,
Mike
2016-1-19
MJones
OK, after an hour of scouring the net and tests to confirm, I have the answer.  THE IPAD CASE WITH A MAGNETIC FLAP TO TURN IT OFF WHEN COSED !!!!!!!
DO NOT MOUNT THE IPAD WITH ANY MAGNETIC CASE!!!
Regards,
Mike
2016-1-19
DJI-Patrick
Have you tried that with other devices ?
2016-1-20
MJones
No, I only have the iPad mini 4 so no other devices to try. See my recent Inspire thread post.  Others have seen this as well.
Regards,
Mike
2016-1-20
solsystem7
Flight distance : 6550331 ft
Maybe someone can answer this for me. When departing away from the home point when viewing on the cached map, I notice a green line which follows P3 outwards from the home point. If I turn the P3 180 degrees and fly back down this line it will take me back to my home point. How can I make sure my controller is facing the P3 when it is flying away or towards me using the cached map? I notice if I unlock the map, it will move depending on which direction I am facing, but how can I know where the P3 is in relation to the controller ? THanks
2016-1-21
