TB48 Red light on, LED #1 flashing, what does this mean?
10151 25 2016-1-20
Ventusb787
The red light is on, and LED #1 is flashing green. I can't do anything to get it to stop. Anybody have any idea what's going on with it?
Thannks
2016-1-20
mmassar64
Flight distance : 176335 ft
So you are unable to turn off the battery is what you mean. The blinking light means its around 20% battery left and the red light means the battery is on.
2016-1-20
Ventusb787
mmassar64@gmail Posted at 2016-1-20 14:35
So you are unable to turn off the battery is what you mean. The blinking light means its around 20%  ...
Yes, I am unable to turn it off.
2016-1-20
Farnk666
Flight distance : 1711394 ft
Have you read the manual?
2016-1-20
DJI-Tim
short press+ long press doesn't turn it off?
2016-1-20
david
Ventusb787 Posted at 2016-1-20 14:27
curious if there was any resolution or if you had to return the battery?  I am having the same issue...
2016-2-23
DJI-Ken
Flight distance : 1515312 ft
david@vintroux. Posted at 2016-2-24 13:26
curious if there was any resolution or if you had to return the battery?  I am having the same iss ...
What issue, you cannot turn off the battery?
One quick press and then a long press. Same way to turn it on.
Th only time I know a battery won't with off is when it's in hibernation and the red light stays on and will not turn off.
If that's your case then leave it alone for 5 minutes until the light goes out, then charge it and that takes it out of hibernation mode.
2016-2-23
david
DJI-Ken Posted at 2016-2-23 21:39
One quick press and then a long press. Same way to tu ...
thank you Ken, I appreciate the follow up.  I am aware of how to turn the battery on and off, but it will not turn off.  There is one LED blinking and the battery will not charge.   I have left it alone for an hour and no change.  Any other thoughts....?
2016-2-23
DJI-Ken
david@vintroux. Posted at 2016-2-24 13:43
thank you Ken, I appreciate the follow up.  I am aware of how to turn the battery on and off, but  ...
Have you tried to charge it ?
2016-2-23
david
DJI-Ken Posted at 2016-2-23 21:51
yes, I've tried to charge and no change.   The charger doesn't even heat up.
with my other two batteries, tb47 & 48, they both behave as they should and the charger gets warm while charging.... not so with the subject battery
2016-2-23
DJI-Ken
david@vintroux. Posted at 2016-2-24 13:55
with my other two  ...
I have never heard of that before. I think the original poster may have not been trying to correctly power off the battery since there was no response after the power off instructions were given to him.
You can call support tomorrow and have the battery sent in for repair 818-235-0789.
2016-2-23
david
DJI-Ken Posted at 2016-2-23 22:04
I have never heard of that before. I think the original poster may have not been trying to correct ...
Thanks Ken,  David
2016-2-23
DJI-Ken
Did it turn off? or are you sending it in?
2016-2-24
david
DJI-Ken Posted at 2016-2-24 07:51
still on,  still one LED blinking.  I purchased the battery less than a month ago through Amazaon.  I have contacted the seller about returning, haven't heard back yet.  Is there another avenue for returning / replacing the battery?
2016-2-24
gybo102
Flight distance : 2426230 ft
david@vintroux. Posted at 2016-2-25 00:43
still on,  still one LED blinking.  I purchased the battery less than a month ago through Amazaon. ...
From my understanding, you go 100% through DJI for battery issues. even if you just bought it.
2016-2-24
DJI-Ken
Just call and they will take care of it. You send it in and when they receive it, they will repair it or send you another battery.
2016-2-24
david
DJI-Ken Posted at 2016-2-24 08:48
Just call and they will take care of it. You send it in and when they receive it, they will repair  ...
ok, will do.  Thank you
2016-2-24
DJI-Ken
No problem at all, thanks for being patient.
2016-2-24
Donnie
Flight distance : 3636782 ft
david@vintroux. Posted at 2016-2-24 10:43
     Funny , I bought mine through Amazon and one of them did the same thing.. Eventually the light goes out.  I have no trouble charging though.
Just dont want you to feel it is only you.....
cheers-donnie
2016-2-24
Donnie
     You did not buy it used did you ?  There is some guy on E-bay selling  the TB-48 for about 130 dollars and it must be reconditioned.  It is just Junk.
I learned a lesson and will only buy new batteries Now.
donnie
2016-2-24
duzak.darryl
david@vintroux. Posted at 2016-2-24 01:43
I just had a brand new battery do this to me as soon as I took it out of the box. I sent it back. It's bricked. DJI should exchange it.
2016-2-24
david
duzak.darryl@gm Posted at 2016-2-25 06:54
I just had a brand new battery do this to me as soon as I took it out of the box. I sent it back.  ...
Thanks everyone, the feedback is helpful and it is good to know that I am not alone.  Spoke with DJI earlier, sent a video of the scenario.  Sounds like they will be replacing, so all will be good.  As for buying on Amazon, it was supposed to be new... seemed new so not sure about the source.   I did fly the Inspire today with my other batteries and was glad the troubled battery didn't cause me more issues than it has so far.  Cheers!
2016-2-24
Ventusb787
Thanks to all for the responses
I had no control of the battery function, I tried a short press, then long press, nothing. Eventually the battery wore itself out, and is in my case with a DEAD label on it. Is this worth trying to send back to DJI to have them look at it?
Thanks
2016-3-5
fans300981e0
Ventusb787 Posted at 2016-3-5 15:59
Thanks
My battery is doing the same thing.  LED #1 is flashing and the red power button light is on. Battery will not turn off, just keeps flashing. Has anyone found a resolution to this? DJI, can I send the battery in for repair? It has less than 10 charge cycles on it. Thanks, Richard.
2017-4-24
Epy6118
It’s 2019 and I’m having this problem for the first time.  Has anybody figured out what the issue is and how to resolve it.   TB 48 battery red light on one green LED blinking won’t shut off won’t charge can
2019-12-21
Epy6118
david@vintroux. Posted at 2016-2-24 16:39
Hi David. Been reading the thread on the TB48 blinking battery with red power light staying on. I’m having the same problem. Did you ever figure out what can be done from home or does it have to be sent to DJI?    And it if it needs to go to DJI. Do you have a number of the person you talked to there?
Thanks, Larry
2019-12-21
