betasteve
Here's a little more. I punched in the last 10-15 GPS points to try to get a track or momentum you were going:
Here's the result (in the same area)
So, unless you spun out of control, you are likely on that track (not taking into account imprecision in GPS reports).
But, you were at 327ft and traveling 1.9 mph (or 2.77 ft/s). Based on that data, and assuming a freefall from 0 vertical acceleration, you are looking at a 4.5 second free fall. The data I already was for 1.1 seconds, so, the picture below is a zoomed in view. I drew an arrow to represent the first 1.1 seconds of recorded flight.
Then, assuming it falls with the same momentum (likely wouldn't - but maybe close) - I copied and pasted the first arrow four times on the same track (to make the additional 4.5 seconds of freefall while on same horizontal track:
All that means, it very well could be in a yard and not the drink.
(Yes, I was bored at work.)
