martin94b
ND Filter is not gonna help you.
As I understand your problem with the bright window and the dark room inside you are facing a very dynamic light situation and that dynamic range cannot be captured by the Osmo.
If you take pictures you could shoot RAW or multiple shots for HDR to extend the dynamic range of your image, but not for the Osmo ;-(
A ND filter would only lower the entire light situation leading to either a longer exposure time (which can be helpful for movies to get more smooth transitions) or increasing the ISO (and thus noise). But the dynamic range stays exactly the same, so its not solving your probem.
A gradient filter is helpful to reduce the dynamic range of landscape shooting, where usually the sky is very bright and the foreground / landmark pretty dark. So the gradient filter reduces that light from the sky but not from the ground and thereby "evens" the light conditions so your camera can capture the entire dynamic range at once.
For your window prblem you would need a dedicated selfmade ND filter just covering the bright window but not the room inside. And then dont move ;-)
But if your problem is not the dynamic range but simply the camera "underexposing" the room - then simply overexpose your recording by either setting e.g. + 1EV or moving the yellow exposure ring to a dark spot. BUT: the information inside the window will be lost due to saturation - if you can live with this limitation it´s simple as this. And again - the ND filter would not help you! |
