A2 Assistant Software V1.9 and Failsafe indication
1547 2 2016-2-15
chris
Hi
When I switch off the transmitter whilst viewing the Control Mode Display in the Basic/RC screen to check Failsafe operation it doesn't move and just stays
at the last switch position. The RC Status bar at the bottom indicates that the transmitter has been lost.
Any ideas?
Thanks
Chris
2016-2-15
DJI-Amy
It's normal since you've turned off the transmitter. Please turn on the RC if you want to adjust the parameter setting.
2016-2-16
chris
DJI-Amy Posted at 2016-2-16 09:05
It's normal since you've turned off the transmitter. Please turn on the RC if you want to adjust the ...
But in the Naza V2 assistant software the pointer moves to the failsafe position to indicate that the controller has gone into failsafe, in the A2 assistant I am having to disconnect the USB and look for the blue led flashes.
2016-2-16
