An answer has surfaced!!
I came across a very informative video on youtube.
The red lines showing on the monitor indicate items / areas that are in focus. The feature is controlled and turned on / off in the settings called Peak Focus Threshold and has settings of NONE - 70% - 80% - 90%. Over exposure warning is also available and appears as black & white stripes that swirls, (Same as they did with the X3), if turned on.
I have found that this feature is not available in the android version of DJO GO.
Nor are the enter / exit travel mode icons on screen.
I guess with android you have to use the switch around the RTH button.
