terrylewis
Flight distance : 3517287 ft
To activate your Inspire 1, the GO App needs an internet connection.
The battery must also be fully charged before using it the first time.
Taking the aircraft out of travel mode can be performed with the RC or within the GO App:
- If you have dual controllers, transforming the Insire requires that you use the Master RC.
- Always place the Inspire on a smooooooth and reflective surface because the landing gear
will slide laterally and it uses the sonic sensors. So don't place the aircraft on carpet or a rough
and sound-absorbing surface when switching between landing and travel modes.
- Also, be sure to remove the gimbal before you transform from flight mode back to travel mode!
To transform the Inspire with the RC:
1) Insert the battery into the Inspire 1
2) Power On the RC first and then the Inspire 1
3) Toggle the Transformaton Switch up and down rapidly at least four times.
4) Wait for the transformation to finish. The aircraft status light should change from it's BLUE color
to the normal status colors (or vice-versa if transforming the other direction)
