IMU Calibration after firmware update required?
2035 8 2016-4-13
Mike.Bott
I calibrate my compass before every new flight.  How often and when should the IMU be calibrated.  I heard of someone's Inspire 1 flying away and DJI-Ken said you should calibrate the IMU before each flight I believe.  What is required?
2016-4-13
Tharg (from the
Flight distance : 120784 ft
IMU after every firmware update (although not strictly necessary it is good practice) or if the aircraft has been subject to a sharp physical shock.
Compass calibration once and just check mod values before every take off.
Totally pointless and run the risk of a bad calibration to do it every flight/
2016-4-13
Alastair
Flight distance : 96631 ft
Tharg is correct.  Personally, I do an IMU calibration after each  firmware update but as far as the compass calibration, I wouldn't do it every flight.  As long as the compass readings are between 1,400-1,600 you're good to go.
2016-4-13
Farnk666
Flight distance : 1711394 ft
Pretty much what they said OP, however I would suggest that you also calibrate your RCs after a firmware update as well.
When and where to do a comapss cal is subject of a bit of argument at times, I usually calibrate compass when flying from a new location that is a reasonable distance from the last one.
A check of your sensor values before takeoff is sound advice.
2016-4-13
DJI-Tim
You don't have to calibrate it every flight. but IMU calibration after every fw upgrade is highly recommended
2016-4-14
dr. D
Flight distance : 8699150 ft
DJI-Tim Posted at 2016-4-14 11:14
You don't have to calibrate it every flight. but IMU calibration after every fw upgrade is highly re ...
Before every Flight I "check IMU" in the MC-Settings as part of my checklist.
It takes only a few seconds. The IMU and the values for the sensors are very important.
What I have seen I believe that DJI wants you to check it before take-off if you want the DJI-Care.
2016-4-14
DJI-BladeStrike
Flight distance : 872694 ft
dr. D Posted at 2016-4-14 12:23
It takes only a few  ...
Agreed, it doesn't hurt to check IMU and compass values. I also agree that you should perform an IMU calibration after every update.
2016-4-14
RichJ53
Flight distance : 1837356 ft
I agree with you and this is on my check list as well!
I wish they would put the IMU on the top menu to make this eay to check. I know that it is not hard, but you need to go into the software three pages deep. Even more with the new P4...
Again, I agree with you and DJI Tim as far as the settings and only reset the IMU after the new FW is installed.
Rich
2016-4-14
06aeb11
Flight distance : 475118 ft
I always forget where IMU is and takes me 5+ min to find it.
2016-4-14
