RichJ53
Flight distance : 1837356 ft
The flight logs need to be uploaded from the DJI server.
Sign into your DJI Go App then select the paper airplane upper left hand side from the ""connect your DJI device screen"". Look at the top right of the flight log page and tap on the cloud icon, then select all and then start your synchronization. This will return all of the log files you have sync'd to your flight log. I hope this helps you.... Should be pretty easy to get them back. If you have another device that has the flight logs intact, just go to the same spot and sync the device and this will update the server with all of your flight logs.
Rich |
