Both dials to control pitch and pan of camera
1870 7 2015-1-16
skip
I use the auto mode most of the time on my camera and want to set the other dial to control the pan. I would of thought that would of been in the drop down menu...  By the way I ended up with 9.2 on my iPad Air 2 and flew a few flights with it but it has something at the beginning with GPS but after first few minutes flew fine... But I decided to go to my S5 Samsung which worked better but doesn't have the big screen....
2015-1-16
DJI-Dboy
China
"set the other gimbal to control the pan"
what's the other gimbal mean?
2015-1-17
skip
DJI-Dboy Posted at 2015-1-18 12:13
Thank you  I meant dial not gimbal...
2015-1-18
DJI-Dboy
China
skip@interactiv Posted at 2015-1-18 17:53
dual control?
details are in user manual:
connect the slave controller to you tablet, press remote icon and choose 'slave'. After that select 'accept' on your master controller.
2015-1-18
skip
DJI-Dboy Posted at 2015-1-18 18:20
dual control?
connect the slave controller to you tablet, press remote ...
I am a single remote guy. I was hoping to be able to do the dials on single remote.
2015-1-18
r-preusser
At least you can change the left dial function between pitch and yaw  in flight by using C1 or C2.
in RC Control Settings just set C1 or C2 to "Gimbal Pitch/Yaw".
Of course it would even be better to use both dials as you suggest.
DJI, why not offering an option for the right dial in the Settings?
2015-1-18
DJI-Dboy
China
skip@interactiv Posted at 2015-1-18 18:35
Got your point, it's a good suggestion,
I'll feedback to RD guys
2015-1-19
kianooshzare.em
Iran
DJI-Dboy Posted at 2015-1-19 17:41
and so i have 2 suggest about controls:
1: we can have a key like shift key that when press it : one of justices control yaw and pitch (forward-backward) and other one control gimbal it will be usefull for fallowing mission capturing
2:
RC1 and RC2 can transfer control to each other . In this case we can combine more complex tracks . For example inside and outside of a room or send inspire immediately  to other location for emergency missions.or other example some one can climb mountain and then take control his bird in sky that sent from base  .Specially will be good  if it can be combine with way-point  program-able flight. also for long-range flights ( 22m/s * 18 min *60 = 22.76 Km )
2015-1-19
