endotherm
Flight distance : 503241 ft
I permanently leave two screws out of each motor, and use a longer thumbscrew to attach guards in the field (or shorter thumbscrews if I don't fit them, which isn't often). I find thumbscrews aren't fiddly and prone to getting lost in the field. I'd hate to be mucking around with small screws and screwdrivers while out flying.
I used string the first time I used them, just because it was there. The second time I didn't. That's when I flew too close to a metal structure which messed up the positioning. It ran into a steel upright support, successfully bounced off the prop guards a couple of times, then fed in between the guards and smashed up the props, just like a paper shredder. Needless to say the string would have saved me in this situation. |
