Android Marshmallow not compatible with P2V+ App
1277 7 2016-5-17
onlymeandyd
Flight distance : 80141 ft
Hi All,
I updated my Samsung Tab S2 to the new Android version last night. Checked Phantom 4 in the Go App and all good. Went to check the P2V+ in the Vision App so I tried to download the latest version (1.0.61) on Google Play and got an error message (in Google Play) to say that the app wasn't compatible with this version (of Android).
I've got another tablet with a compatible version of Android but I wondered if anyone had a workaround for Marshmallow (version 6.0.1).
Thanks.
AndyD
2016-5-17
DJI-Paladin
Flight distance : 2408 ft
Hello Andy, it is recommended to run the DJI Vision in IOS or Android 5.X.
2016-5-17
roy
Download the app directly from DJI and install it. You won't get the computable message then.
2016-5-19
wednesdayschild
Flight distance : 109446 ft
Ok - Am I blind or what? Where are all the dowloadable applications?
2016-7-25
Northofthe49th
wednesdayschild Posted at 2016-7-25 15:21
Interesting,
The downloads page link is here but takes you back to the Google Play download.
http://www.dji.com/product/phantom-2-vision-plus/info#downloads.
Will have to let another using same version of Android chime in...
2016-7-26
wednesdayschild
Northofthe49th Posted at 2016-7-26 23:16
Interesting,
Thank you. Now I have a GPS issue. I did the upgrade ceramic puck to the GP 1575.25.4.A.02 and now instead of getting more satellites, I get zero. Very frustrating. I have tried just about everything. Any tips, suggestions or downloads?
2016-7-26
kirk2579
Flight distance : 37415 ft
wednesdayschild Posted at 2016-7-26 23:34
Thank you. Now I have a GPS issue. I did the upgrade ceramic puck to the GP 1575.25.4.A.02 and now ...
On the GPS check:
make sure cable is plugged solid into main board. easy to come loose.
check the solder points , maybe reheat / reflow the solder.
good luck and have fun flying!
2016-7-29
lol....i just signed in and read this. It was not working so I just upgraded to the P4 and I'm way better for it. I'll keep this gem for at least 2 more years. Thanks for the advice. If I ever feel like tinkering around with the P3 again, I'll do what you said. - Kumba
2017-7-10
