Hawk Knocked my Drone Down: Lessons Learned
2617 15 2016-6-5
danasay
Although this is an unpleasant ending, the lessons learned are valuable.  I'm hoping this might help others to NOT learn the hard way.
Lessons Learned:
Monitor for large predatory birds.  If you are looking in the camera fpv display, be aware your field of view doesn't include an attack from above or behind.
Maintain an unthreatening distance away from large birds in tall trees.
If a bird flies close to the drone, rapidly fly away from the area.
2016-6-5
DJI-Paladin
Flight distance : 2408 ft
Sorry for your issue, danasay. If you need repairing service, you can get in touch with our tech support via support@dji.com.
2016-6-5
MD_Icarus
The video is private.  I can not see it.
But, here is one for you.  I was able to take it away from the angry bird!!
2016-6-5
danasay
DJI-Paladin Posted at 2016-6-6 12:00
Sorry for your issue, danasay. If you need repairing service, you can get in touch with our tech sup ...
Thanks DJI Paladin, but the drone is fine.  Not as damaged as one might imagine; I'm flying it again tomorrow.
2016-6-5
MD_Icarus
It's not private now, I saw it.
Close call there! Maybe there was a nest in the area?  They will defend their nest area.
I try to stay away from them.  They can take down a goat!
2016-6-5
Phantomski
Flight distance : 14869882 ft
Damn! U r also quite comfortable flying rather close to branches and so on.. I have quite a hard time trying to judge distance in the wide angle....
So, what was the damage? i assume the tree slowed you down, if it was straight to the ground, would have hurt more!
2016-6-5
huntcool001
You might want to test flying it to monitor any hidden damage to your motor.
I think the eagle kicks the plane down, instead of grabbing it like what normally see in documentary?
2016-6-5
talk2t_c
MD_Icarus Posted at 2016-6-6 06:09
But, here is one for you.  I was able to take it away from ...
See you have a nice nest site at 3.34 - think about not p88sing it off.
2016-6-6
talk2t_c
Four warnings - let it go.
2016-6-6
danasay
Thanks to the short trees softening the fall, there was minimal damage to P3P:
Tiny nick on one propeller (swapped with spare blades that came with P3P).
Three of the shell screw holes were cracked.  I temporarily added zip ties to the rear arms to prevent separation of shells.  Tested satisfactory.  I'll improve the single zip tie configuration when I get home.
The hawk flew away after contact; don't know the extent of damage on the hawk.
I flew my P3P along the cliffs yesterday.  It still flies flawlessly.  I'll look at the recorded video Friday.
2016-6-7
munceycerellia
Flight distance : 82638 ft
2016-6-7
Ricky Wu
Flight distance : 1360719 ft
Are you using any filters ? Nice work
2016-6-16
danasay
Ricky Wu Posted at 2016-6-16 20:58
Yes, I just leave a ND8 filter under the original polarizing filter.  I'm too lazy to change it for each flight and I don't want to wear out the threads.
2016-6-16
ZeeKeezer
Flight distance : 13970 ft
First sorry.
2nd, the music, the everything was amazing... lol
2016-6-16
danasay
flydodom Posted at 2016-6-17 22:06
Oh dear..! Well, in both instances you guys are both made a mistake but descending, it is any animal ...
Thanks flyodom, that makes good sense.
I would like to hear more perspectives from other pilots, regarding most effective evasive/avoidance maneuvers.
2016-6-17
Cessna172
danasay@cox.net Posted at 2016-6-8 06:13
Good question...
Considering the props are fully loaded supporting the load of the Phantom and spinning at such high speed, I would "imagine" that most birds that make contact with a Phantom suffer slight to severe injuries.
I don't know of any evidence but the birds would probably make first contact with the drones propellers via their extended claws (making an assumption).
If that's the case, I would assume the propellers are capable of severing their claws/talons/digits or whatever they are called.  The props can delier a very nasty injury to human fingers and hands which are generally thicker than a Hawks talons....aren't they?   (I've never been that close to a Hawk).
Now an Eagle can have claws/Talons that are as big or bigger than human fingers.
Hawk's claws are far smaller.   Generally smaller than human fingers.
2016-6-17
