S900 now has A3 and X5
12163 35 2016-6-19
Arrow1969
Flight distance : 400577 ft
I just finished converting S900 to the new A3 and mounted a X5 on it it weighs in at 7K and on a 16000 I'm getting 20 minutes flight time.
2016-6-19
DJI-Adela
Hello.
Impressive work!
Thanks for your support to DJI products.
2016-6-20
nomad65
Hi Arrow , would this set up be possible on S900 with A2 and Data link ?
Thank you
2016-6-21
DJI-Jamie
Flight distance : 112405 ft
nomad65 Posted at 2016-6-21 23:36
Thank you
The X3/X5/XT mounting kit is only recognized by the A3/LB2 combination. It would not work with the A2.
2016-6-21
nomad65
DJI-Jamie Posted at 2016-6-21 19:10
The X3/X5/XT mounting kit is only recognized by the A3/LB2 combination. It would not work with the ...
Thank you man !
2016-6-22
InstaQtr
Qatar
Thank you Arrow for sharing the photos of the beast ..
Did you test it ?
Or could you please share a video link of your work .. Cuz I'm planning to do the same thing to my s1000
2016-6-22
Arrow1969
InstaQtr Posted at 2016-6-22 17:59
Did you test it ?
Hi,
Here you go, plan on making another one tomorrow with the X mount on, also demonstrating point of view and the waypoints weather permitting.
Tony
2016-6-22
jsb2000
Flight distance : 1415194 ft
South Korea
let me ask something
plz tell me about landing leg
I have s1000 ,a3 ,lb2 everyting work but f1-f8 didn't work so my langing gear didn't work
can you shere your wisdom ?
thank you
2016-6-22
Arrow1969
jsb2000@naver.c Posted at 2016-6-23 02:31
I have s1000 ,a3 ,lb2 everyting work but f1-f8  ...
Hi,
I have mine plugged into F8 and it is set to intelligent learning gear and it works fine, Will automatically retract after takeoff.
Are you getting a red or green LED on the undercarriage indicator, try plugging it into the opposite end we mistakenly thought f1 was actually f8.
Cheers Tony
2016-6-22
Arrow1969
DJI A3 S900 LB2 Point of Interest Air Test.
2016-6-23
jteeple
Question- So it looks like from your install picks your tied directly in to the landing gear feed like the Z15  does the X5 take 6S voltage? I could of swore DJI specs said it was 19V operating voltage? If it doesn't are you using separate battery or a step down unit?
2016-6-23
Arrow1969
jteeple@iconatt Posted at 2016-6-24 01:10
Question- So it looks like from your install picks your tied directly in to the landing gear feed li ...
Hi,
Yes the X5 will take a 6S no need for a step down or separate battery, this was confirmed by a DJI engineer couple of weeks ago via a FB https://www.facebook.com/groups/MATRICE600/
2016-6-23
jteeple
Cool I'm putting my order in asap can wait to get rid of my Z-15 BMPCC I had it with that camera. Plus that large mount plate looks like a perfect home for Guidance. It looks like its offset enough to the front that the side cameras should not be obstructed if the gear is down. This is going to be awesome!
2016-6-24
mikeLmedic04
Flight distance : 256519 ft
Hello - I have been flying an Inspire pro and keen to move to a hex with my X5 camera.
Lightweight with redundancy is the aim for me. Can you fly this with dual batteries, say 8000s?
This would be my first "build" and planning on the A3 and LB2 combo - so any advice would be great.
2016-9-6
DJI-Jamie
mikeLmedic04 Posted at 2016-9-6 22:43
Lightweight  ...
That would be posible if you use a y spitter for the XT60 connection.
2016-9-6
Swiss-Tony
Flight distance : 3312018 ft
Hi Arrow,
Could you post the parts list that is required to achieve this?
I know you used to fly a GH4/Z15 as do I, are the results as good?
Do you get full camera functionality through the Go App?
2016-9-6
JimBinDallas
Great work!  Could you please post a list of what parts we need to order for the complete conversion?  For example, I have an S900 with an A2 and a GH4 gimbal/camera.  What would I need to buy to transition to your system?  I've found that just looking at pictures sometimes allows me to miss important (and expensive!) things. Thanks in advance. jim
2016-12-25
DJI-Jamie
JimBinDallas Posted at 2016-12-26 07:17
The crux of the expensive components are as follows:
The A3 flight controller
Lightbridge 2
The M600 X Mounting Kit
2016-12-26
Arrow1969
DJI-Jamie Posted at 2016-12-27 04:34
Have also juts setup my 900 with the A3 pro kit and have just test flown it.
2016-12-27
Kankles
Flight distance : 3963865 ft
I have an extra M600 X mounting kit if anyone wants to grab it for cheap.  Never opened, PM me
2016-12-27
DJI-Jamie
Arrow1969 Posted at 2016-12-27 17:19
That's a nice rig you got there, Sir!
2016-12-27
Arrow1969
DJI-Jamie Posted at 2016-12-27 15:22
Thank's Jamia. {:4_181:}
2016-12-27
Arrow1969
DJI-Jamie Posted at 2016-12-27 07:22
Just been out testing the 900 now it is completely set up with A3 Pro kit and X5R.
2017-1-7
Robin UAV
DJI-Jamie Posted at 2016-6-21 10:10
Jamie, a little correction if I may: It will be recognized by N3 and LB2 as well.
2017-1-7
Robin UAV
Kankles Posted at 2016-12-27 02:25
Yes, I am! Just sent you a PM.
2017-1-7
DJI-Jamie
Robin UAV Posted at 2017-1-7 14:50
That post was before the N3 was released, but yes you hit the nail on the head.
2017-1-10
Hazardpro1
**** The author has been banned or deleted automatically shield ****
Where are you based (re mounting kit)
H
2017-2-11
Props-n-blades
Belgium
If the X5 and X3 work with the M600 conversion and the A3/N3 controller, does the X4 work as well then?
2018-3-21
Bruno Soares
Brazil
I have N3 + LB2 + X5, I have all the X5 commands on the screen, but I can not get the X5 video image (FPV) on my tablet, they could help me, because I have an urgent need to use the X5.
2018-5-8
Bruno Soares
Brazil
Did you have to make any changes to the cables? I made this S900 conversion, but it is not displaying the X5 video on the Ipad.
2018-5-8
davidep
Flight distance : 64934 ft
I'have a S900 +zenmuse Z15 and Sony nex7. But I need to geotagging the pictures. (+o- 20cm.) With
and X5 or X5R
Lightbridge 2
is possible to geotag the picture?
Thank You.
2018-5-26
Paul Suthard
Flight distance : 116634 ft
Arrow1969 Posted at 2017-1-7 12:42
did the rear clips for the x5r come in the kit? I don't have any
2018-7-13
djiuser_EaI0Ik9llpSu
Mexico
Hello
I have a S900 too. I am looking for an adaptor  or  extension,  like the one you use for the X5 camera.
Can you help me, and tell me where I can find that one?
Thank you
Ferudi
2018-12-24
Mexico
Hello
Thank you
Ferudi
2018-12-24
HughGlassVPN
i have the s900 and x5r, im currently using the x3 adapter. do i need a differnt adapter to run the x5r
2020-12-5
Gavithis
Thanks for the info
2021-1-8
