j5255
Flight distance : 5291158 ft
Today I was out doing touch and go's in ATTI mode, in an empty soccer field with very light winds. All was going well until I noticed that someone was approaching me from the right. For safety conecerrns I decided to land and kill the power. The landing was perfect, but when I went to cut the power, the P4 tilted forward and turned upside down in the grass and began to shoot around the field, first going this way and then that way as well as cutting a fair amount of grass. Mean while, I was trying to cut the power, but no method seemed to work. It finaly stop in some deeper grass and I shut the battery off manually.
Lessons Learned: 1) If distracted while flying in ATTI mode, switch to P mode. 2) A healthy P4 sure covers a lot of ground when it is upside down. 3) Although the P4 does cut grass very short, it wears the tips of the props off very quickly.
Changed the blades, check all the controls, inspected the P4 for damage, there was none. All is well. Back to the big blue !
