rod
New Zealand
Hi, Have you tried taking the props off again? (and remembering to use the shorter screws , because the long ones will cause motor damage.)
I have prop guards and my bird has had no problems. (In fact it flies so text book that it is scary!) I would suggest going through the recalibration of your RC and IMU (but not advanced- that seems to cause more trouble than it solves unless you are very experienced- there is a long technical thread on this site- well worth a read).
I would add that when taking off, I have to give full throttle for lift off , otherwise it will tip back. Then I let it hover at a couple of metres to stabilize itself-(and me!.) It should sit there as if on a pole, so if you have it wandering, it sounds like it could be the RC. Let us know how you get on and what you have tried to fix it.
Cheers!
Rod |
