THIS ZONE CANNOT BE UNLOCKED
2957 30 2016-7-12
LICENSED PILOT
Flight distance : 692090 ft
I have been working with a construction company, buildin an expansion next to a prison. Imagine my surprise this morning when I began my monthly geo map flight when the whole area turned red, no fly zone. Is there a path to work this out? The construction company is not happy.
On another topic, is there a link showing steps in unlocking yellow and green zones? Tried the DJI website but it was not helpful. Thanks for any help.
2016-7-12
str1776
Flight distance : 22530 ft
Can I ask what your  distance restriction is a mile and a half or more ?
Thanks for sharing I get it maybe some type of  short  term exemption for your  Proof of contract with business address location
That would Just make to much sense.
Happy flights good luck
Steve
2016-7-12
terrylewis
Flight distance : 3517287 ft
From "Blade Strike" over on RCGroups: "For operators who are still not able to access or unlock areas where they are authorized to fly, please send a note to DJI at flysafe@dji.com".
2016-7-12
DJI-Jamie
Flight distance : 112405 ft
Have you tried getting in contact with the FlySafe team about this issue? Just to clarify have you been using the new Geo system prior to this incident?
2016-7-12
LICENSED PILOT
str1776 Posted at 2016-7-13 04:57
Thanks for sharing I get it ...
the red zone extended appro.  1/2 mile beyond the fence...
2016-7-12
LICENSED PILOT
DJI-Jamie Posted at 2016-7-13 05:20
Have you tried getting in contact with the FlySafe team about this issue? Just to clarify have you b ...
I upgraded to 2.8.4 just before this job, big mistake....
I have contacted DJI.
2016-7-12
DJI-Jamie
LICENSED PILOT Posted at 2016-7-13 05:47
FlySafe will get you back on track to have the zone unlocked again. I'm unsure whether you would need to resubmit any paperwork, but it should be more streamlined since you had permissions prior to the update.
2016-7-12
R&L Aerial
Flight distance : 298100 ft
LICENSED PILOT Posted at 2016-7-12 17:47
What happened to you is why I didn't upgrade
2016-7-12
LICENSED PILOT
DJI-Jamie Posted at 2016-7-13 05:57
FlySafe will get you back on track to have the zone unlocked again. I'm unsure whether you would n ...
NO. I never had DJI permission. I was working this job regularly w/o any red zone warning until today. I just updated to DJI GO 2.8.4, then got the red zone...
2016-7-12
flighttime1
Flight distance : 906352 ft
I'm not 100% positive but I believe prisons are one of the no fly zones you can't get clearance on. DJI might have done you a favor and avoided some prison guard shooting your bird out of the sky thinking it was part of a contraband delivery system.
2016-7-12
DJI-Jamie
LICENSED PILOT Posted at 2016-7-13 08:50
NO. I never had DJI permission. I was working this job regularly w/o any red zone warning until to ...
Then you would need to submit paperwork showing that you have permission to fly within the vacinity of the prison. There is some other basic information that the FlySafe team will ask for, but you should get up and running quickly if you get in contact with them as soon as possible.
2016-7-13
LICENSED PILOT
flighttime1 Posted at 2016-7-13 11:20
I'm not 100% positive but I believe prisons are one of the no fly zones you can't get clearance on.  ...
Give me a break FT1!{:4_157:} I'll assume you were not serious...
I am not some kid with a Phantom, but a licensed commercial pilot with a 333. (and a retired chief of police, to boot). I worked through the construction company, they hired me, and have the warden's approval.
This is Arizona , the guards would have turned my bird into white mist the first time I tried it w/o authorization!!
2016-7-13
LICENSED PILOT
DJI-Jamie Posted at 2016-7-13 23:12
Then you would need to submit paperwork showing that you have permission to fly within the vacinit ...
Thanks, Jamie. I started the process and Blair Tang was quick to reply...
2016-7-13
DJI-Jamie
LICENSED PILOT Posted at 2016-7-13 23:23
No problem. You should be back up in no time.
2016-7-13
LICENSED PILOT
DJI-Jamie Posted at 2016-7-13 23:54
Puzzling, when I tried to fly at the prison, a huge red NFZ popped up on the DJI GO APP. However, When I check the DJI NFZ map, it's not there...
2016-7-14
DJI-Jamie
LICENSED PILOT Posted at 2016-7-14 23:53
Puzzling, when I tried to fly at the prison, a huge red NFZ popped up on the DJI GO APP. However, W ...
Do you have the Geo System enabled via the General Settings? Are these screenshots taken with the aircraft on? The NFZs should appear when the unit is connected to the app.
2016-7-14
LICENSED PILOT
DJI-Jamie Posted at 2016-7-15 00:58
Do you have the Geo System enabled via the General Settings? Are these screenshots taken with the  ...
I was referring to the NFZ site
http://www.dji.com/flysafe/no-fly
2016-7-14
terrylewis
LICENSED PILOT Posted at 2016-7-15 01:12
IF you updated firmware, GEO is probably showing this, with the restriction over Red Rock:
2016-7-14
LICENSED PILOT
terrylewis Posted at 2016-7-15 01:26
Not my day I guess.
I cannot see the red zone on the website nor in the app. Version 2.8.4
2016-7-14
LICENSED PILOT
LICENSED PILOT Posted at 2016-7-15 01:37
Not my day I guess.
I can only see the nearest NFZ in my city, but when I slide the map over to metro Phoenix with lots of NFZ can't see a single one (?)
2016-7-14
DJI-Jamie
The regular Fly Safe section unfortunately has an outdated map. You would refer to the Geo System's section in order to get the correct map:
http://www.dji.com/flysafe/geo-system/map
I believe the correctional facility you are around is present as a NFZ based on the picture you provided.
2016-7-14
LICENSED PILOT
DJI-Jamie Posted at 2016-7-15 03:33
The regular Fly Safe section unfortunately has an outdated map. You would refer to the Geo System' ...
AH, there it is. Thank you very much.
I'm still puzzled why I can only see my local airport red NFZ (in DJI GO) but not the ones in and around the Phoenix metro area (over half a dozen controlled airports.) Does the bird have to be within a certain distance from the NFZ to see it in the app?
2016-7-14
DJI-Jamie
LICENSED PILOT Posted at 2016-7-15 06:31
I'm still puzzled why I can only see my local airport red NF ...
Yes, you do need to be closer in order to see the NFZ in the DJI Go app. You should be able to see NFZ indicators at around a 5 mile radius from your current location if you have an active internet connection.
2016-7-15
LICENSED PILOT
DJI-Jamie Posted at 2016-7-15 22:21
Yes, you do need to be closer in order to see the NFZ in the DJI Go app. You should be able to see  ...
Ah, thank you!
2016-7-15
DJI-Jamie
You're welcome.
2016-7-15
eggbeater
Flight distance : 3502972 ft
Block the GPS signals to your Inspire with a tin foil cap and fly in ATT.
2016-7-19
LICENSED PILOT
eggbeater Posted at 2016-7-20 11:49
Not practical. The mapping app relies on GPS...
2016-7-20
DJI-Ken
Flight distance : 1515312 ft
I'm sure the authorities would be really nice to you if there was an incident and they found your aircraft had been tampered with.
Have you seen the FAA fines and penalties, I bet if anything were to ever happen and you had an accident you'd be on the maximum side of the penalties. is it really worth it ?
2016-7-20
LICENSED PILOT
DJI-Ken Posted at 2016-7-21 00:21
I'm sure the authorities would be really nice to you if there was an incident and they found your  ...
Right. I worked too hard for my commercial pilot license and 333 to just piss it away...
2016-7-20
DJI-Ken
LICENSED PILOT Posted at 2016-7-21 01:49
Yes for sure, me too.
2016-7-20
