New Ronin-MX Firmware Now Available
3539 9 2016-7-22
DJI-Paladin
Flight distance : 2408 ft
Dear DJI Customer,
New Ronin-MX firmware updates are now available: IMU v2.0, GCU v1.2 and ESC v1.4.9.17. Use Ronin-MX Assistant V2.4 to update.
What’s New:
1. Fixed abnormal behavior when mounting the gimbal in upright-mode with pan axis push mode enabled.
2. Fixed issue where Auto Sleep is activated in one mode of operation but wakeup is in a different mode.
3. Added gimbal endpoint protection. The angle between the gimbal and the aircraft nose will be set as the maximum selectable endpoint value to avoid cable obstruction when connecting Lightbridge 2 to the gimbal.
4. Added DJI A3 and Futaba remote controller support. Program a 3 position switch on channel 7 on a Futaba remote controller to switch the gimbal between Free, Follow and FPV modes. Ronin-MX landing gear protection will need to be disabled otherwise the pan axis will be limited to ±30 degrees. Toggle channel 6 switch on the Futaba remote controller to the lowest point, or toggle the FUNCTION switch on the Ronin-MX remote controller to the upper position to disable landing gear protection.
5. Added ESC firmware upgrade support. Improved the modulation ratio to increase motor torque output.
6. Added support for Remote Start/Stop firmware updates.
7. Added support for the DJI Focus Expansion Module.
8. Fixed an incorrect battery temperature display issue in the DJI Ronin-MX Assistant.
Notes:
1. If you are upgrading the Ronin-MX on the Matrice 600, power off the Matrice 600 or disconnect the CAN cable first to prevent upgrade failure.
2.  Click the Default button in DJI Ronin-MX Assistant to enable gimbal endpoint protection. Endpoint values for the pan axis will be set to -179° and 179°.
2016-7-22
ckasianczuk
How long does it take to download the GCU firmware update to the Ronin-MX? Mine has been running for 10 mins and I'm starting to get worried.
2016-7-22
DJI-Paladin
ckasianczuk@hot Posted at 2016-7-23 07:17
How long does it take to download the GCU firmware update to the Ronin-MX? Mine has been running for ...
Did you update your Ronin MX when it connected to the M600 platform? It is necessary to disconnect the Ronin and M600 when doing the update for Ronin.
2016-7-24
Nateharbin
What is the normal download time for update? I've been waiting 15 minutes and i'm getting the color wheel of death.  I don't have an M600.  Its just the MX connected to iMac 10.10 through usb cable. Thanks for the help.
2016-7-26
Nateharbin
how long does the GCU update take? I've been waiting 25 minutes and i'm confused if it's making any progress
2016-7-26
Nateharbin
To update, i had to force quit the assistant app after around 45 minutes and when reopened the app GCU update worked within 20 seconds.  I had to do the same thing for every ESC update.  Once reopened, every update went extremely fast.
2016-7-26
DJI-Paladin
Nateharbin@gmai Posted at 2016-7-27 01:07
how long does the GCU update take? I've been waiting 25 minutes and i'm confused if it's making any  ...
This usually takes about 5 minutes. Have you tried with different network service? Our developers are also checking the server status.
2016-7-28
kazakov-sasha
Russia
ronin mx or ronin big brother?
Help me with choice pls
2016-8-10
DJI-Paladin
kazakov-sasha@y Posted at 2016-8-11 04:21
Please check it here http://www.dji.com/products/compare-ronin
2016-8-10
Aaron B
Nateharbin@gmai Posted at 2016-7-26 09:35
same issue as well, and we powered cycled and it worked
2018-2-21
