Max altitude 120m and distance 500m? HELP.
6099 13 2016-7-22
tehuma
Estonia
Hello.
i got my new drone and when i go to fly outside my drone stops at 120m height and 500 radius. and even if i tap the advanced flight mode i still cannot enter more than 500m to the box. (both altitude and distance) 500 to altitude but still stops 120m? i have latest software updated to my iphone 6s plus and everything should be fine. i heard that theres some restrictions on but how to unlock them? On internet online shop it says max height 500m and radius 2km but im stuck here. Sry if this thread has been here before but can anyone explain me step by step how to bypass 120m altitude and 500 radius block.
Thank you
2016-7-22
tehuma
Estonia
And drone is Phantom 3 Pro
2016-7-22
DJI-Paladin
Flight distance : 2408 ft
Please disable the distance limit option which is under the box when the drone is on.
2016-7-22
PhanFran
Flight distance : 4804163 ft
DJI-Paladin Posted at 2016-7-22 17:24
...and for God's sake, please READ your manual before doing anything with your aircraft, otherwise you will probably hurt your drone, yourself, or possibly others
2016-7-22
mikelt006
Flight distance : 336880 ft
Israel
Don't you check the most basic settings before flying? like open the menu settings ?
2016-7-22
tehuma
Estonia
Ive enabled Max distance but still cannot go further than 500m (distance)
2016-7-22
tehuma
Estonia
okay i got this now.. SO basically i have to leave this enable max distance button off. so i can fly up to 2km range?
2016-7-22
Boblanglois52
Flight distance : 129567 ft
tehuma Posted at 2016-7-22 07:15
You have to do this while you have the aircraft connected to the app.
2016-7-22
fans6199dace
I have a Phantom 3 Pro & my flight height is set for English (NOT Metric).  But I set it & it goes back to Metric.  However, even so, height @ 120 meters (about 390 feet) I can only go up about 30-40 feet.  WHY????  And as for distance, I can only go about 75 feet.  WHY????
2017-7-24
PaulSouthport
Flight distance : 1448799 ft
log out of DJI Go, then log in again.
2017-7-24
Cabansail
Flight distance : 136686 ft
fans6199dace Posted at 2017-7-24 14:16
Sounds like you have Beginners Mode turned on.
2017-7-24
TheMaestro
i need some urgent help/ i have a phantom 3 pro & the IMU fails to Calibrate every time i try it. And now i have been grounded because of that for over 4 months?
2019-2-4
TheMaestro
2019-2-4
Mark The Droner
Flight distance : 2917 ft
You don't want to fly with a bad IMU, so being grounded is a good thing.  If it fails to calibrate, you want to get that repaired.
Good luck
2019-2-4
