S1000 Premium Frame Arm Power connectors to PDU
1149 3 2016-8-4
damiangarcia
Hi,
I am building a S1000 Premium and I have a question regarding connecting the power cable connectors from the frame arms into the PDU.   Try what I may, I cannot get the connectors to attach securely into the sockets on the PDU.
The manual and online Wiki is somewhat vague in how the conector pins need to be configured (http://wiki.dji.com/en/index.php ... Mounting_Frame_Arms).
Attached is how the pins are currently look.  Are these correct or do I need to pull the small pieces of gold connectors to the side of the pin out so that they are straight?
Any help would be appreciated as I do not want to straightening pins unceccesarily for fear of damaging them.
Regards,
Damian
Side on view of frame arm power pin
Head on view of frame arm power pin
2016-8-4
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, are you saying that they don't push in easily or is it a loose fit?
2016-8-4
damiangarcia
DJI-Jamie Posted at 2016-8-4 23:10
They would not push in easily and I did not want to force them.  However, since posting this question on the forum, I have seen a video on Youtube where the presenter shows applying a small amount of force in order to get the pins into the PDU.  I have followed this example and am pleased to say that all of the plugs are now secured to the PDU and the heat wraps applied.
Come to think of it, it makes sense for the plugs to be a tight fit, as if they were easy to fit/loose, they would come out during flight.
2016-8-8
DJI-Jamie
damiangarcia Posted at 2016-8-9 04:20
They would not push in easily and I did not want to force them.  However, since posting this quest ...
Exactly, they are supposed to be a tight fit. I'm glad to hear you're on your way to getting up and running.
2016-8-8
