A3 sensitivity gain
3848 22 2016-8-30
ckk.post
Denmark
If the drone responds to quickly what should you adjust on
a3 attitude gain is different with respect to a2
one must adjust sensitivity gain yaw brake attitude
or advanced gain
have difficulty and understand what should one adjust on
it reacts to sharply  on pitch and roll
2016-8-30
ckk.post
Denmark
I try again i have A3 pro
and
the drone react too quickly on the controller in gps mode
it stop to violently in the air when i realse the stick on controller
I come from a2 controller there  you adjust one Attitude gains pitch roll yaw
on a3 it is different how do I do it on a3 is it advance attitude or is it sensitivity gain or  what ???
Regards keller
2016-8-31
liusheng_2001
China
ckk.post Posted at 2016-8-31 21:01
and
Hello keller,
Similar to my case. Our copter installs A3. We test it these days. It reacts very very fast. Seems adjusting "control exp" works.
However in my case, the copter is difficult to reach stable hover.....
2016-8-31
ckk.post
Denmark
liusheng_2001@1 Posted at 2016-8-31 16:43
Hello keller,
Similar to my case. Our copter installs A3. We test it these days. It reacts very ve ...
my x8 is flying nice enough
it is only in GPS mode it stops crazy fast
too violently although I release sticks very slowly
2016-8-31
DJI-Jamie
Flight distance : 112405 ft
liusheng_2001@1 Posted at 2016-8-31 22:43
Hello keller,
What are you running the A3 on? Is the drone drifting randomly or is it more of a toilet bowl effect?
2016-8-31
DJI-Jamie
ckk.post Posted at 2016-9-1 00:51
too violently although I r ...
Have you already tried adjusting the Control EXP settings?
2016-8-31
ckk.post
Denmark
DJI-Jamie Posted at 2016-8-31 20:32
I know not where I need to adjust ?
that's what I am  asking about on  how
and
on
Regards keller
2016-8-31
ckk.post
Denmark
ckk.post Posted at 2016-8-31 21:11
absolutely no one who knows anything
2016-9-1
mradeck
Flight distance : 1902753 ft
i see axact the same behavior with my big flat 8 (over 20kg) it stops much to hard
in which direction should we change control exp?  can someone provide a screenshot
2016-9-22
Swiss-Tony
Flight distance : 3312018 ft
I had this problem on my S1000+.
The actual CG on the craft for IMU mounting was -100mm (landing gear up) with GH4 attached. I found that reducing this to -50mm seemed to improve it.
I think the unit may be over compensating for the weight it is carrying in GPS.
2016-9-23
ckk.post
Denmark
Swiss-Tony Posted at 2016-9-23 12:35
The actual CG on the craft for IMU mounting was -100mm (landing ge ...
Everything is measured as it should be
but may be I should tweak it and see if it gives something
thanks for reply
2016-9-24
ckk.post
Denmark
just one more question I have not tried it yet
but do you still use this  setting
with only half the setting of the center of gravity
And are there other who have tried it
2016-9-30
Swiss-Tony
I think I've cracked this issue on S1000+, A3, GH4, LB2
IMU vertical -80mm (use your own horizontal measurements)
Compass vertical -250mm  (use your own horizontal measurements)
Basic Gains, increase to 100.
Braking, reduce to 20.
Attitude increase to 50.
Advanced 100 (default)
Expo set at default.
These settings give me smooth response, stable hover (no toilet bowl) and the frantic braking is far better.
Try it and let be know what you think.
2016-10-2
jakub
Flight distance : 431795 ft
Czechia
Swiss-Tony Posted at 2016-10-2 17:53
IMU vertical -80mm (use your own horizontal ...
How did you manage to set BRAKE to 20? For me 80 is the minimal value...
Thanks
2016-10-3
Swiss-Tony
Sorry, Typo.
Reduce it to 80 which is the minimum
2016-10-3
ckk.post
Denmark
IMU vertical -80mm
it means you have modified it to -80 and not -50
as you started with and write ?
2016-10-3
Swiss-Tony
I moved it back after I set the gains and it was OK
2016-10-4
ckk.post
Denmark
Swiss-Tony Posted at 2016-10-4 18:04
Thanks will look at it over the weekend
my center of gravity is only -40
so I'll try to -30 and see if it gives something
2016-10-4
fanse60b875e
Costa Rica
Hello I have a couple of questions to see if they can help me, I have some similar problems in my X8 with A3 I have normal not pro and it happens to me it is very violent in the controls and reacts very fast, then I have a problem that I think it is The bigger the voltage q indicates to me the iOSD MKII is fickle low and it goes up just as my X8 is not stable ups and downs. If someone can help me or give me advice that I do much agradesco .....
Greetings Jimmy
2016-12-7
fansf238540c
Mexico
Hello DJI
But any chance can you guys do some guide or table or demo to adjust the s1000, some table similar to the DJI A2, to give us some idea were to start those values?
thanks
2016-12-7
DJI-Jamie
fansf238540c Posted at 2016-12-8 14:50
Hello DJI
I can pass the request along to see if it's possible.
2016-12-8
fansf238540c
Mexico
thank you Jamie, that can help us a lot.
2016-12-8
CamFly Films
Flight distance : 1074564 ft
I am still struggling with gains for S900 / A3 / LB2 / X5
Everything at default. the 900 is sluggish at everything but it also drifts randomly / toilet bowl when hovering (Not every minute but too much to not being annoying! ) I placed everything correctly on board, now  is it the CG? How do I find it? It is by default at -150. Please help, too many questions at the same time. thanks.
2017-5-17
