Ronin MX Mounting plate with X5
1479 4 2016-8-30
SkyPod.nyc
Flight distance : 170151 ft
I have a Ronin MX mounting plate attached. Can I attach my Zenmuse X5 to it or do I need to use the one that came with the Zenmuse x5 mounting kit?
2016-8-30
DJI-Jamie
Flight distance : 112405 ft
If you are using the M600, then you would need the M600 X Mounting Kit.
2016-8-31
SkyPod.nyc
DJI-Jamie Posted at 2016-8-31 16:19
Yes, I have both  the Ronin MX and the  Zenmuse mount  kits. Currently I have the Ronn MX mount  kit with vibration dampers attached and It looks as if I can attach the Zenmuse system  to the same mount. I'm trying to avoid changing the mount system every time I swap between the Zenmuse and the Ronin Gimble. Thanks.
2016-8-31
SkyPod.nyc
SkyPod.nyc Posted at 2016-8-31 19:08
Yes, I have both  the Ronin MX and the  Zenmuse mount  kits. Currently I have the Ronn MX mount  k ...
Ok, figured it out myself. Tha answer is YES. But I removed the Ronin Gimbal turret attachment just to save  weight.
2016-9-2
blackice2999
SkyPod.nyc Posted at 2016-9-2 12:58
Can you upload a picture of your construct? I try the same. Thanks
2018-7-19
