Osmo Pro X5 Won't Auto Focus
5522 4 2016-8-31
maurymcc
Flight distance : 37949 ft
Hello all
Just received my Osmo Pro X5 and I'm getting great results -- but the problem is that the camera won't auto focus unless I tap the iPhone screen to refocus the image.
I have calibrated the lens for this iPhone, and I get great "infinity" shots. However, when I sweep from a distance shot, say 25 feet, to a subject only about 4 feet away, I have to tap the screen to reset focus. THEN, when I sweep back out, the distance is now blurry.
Also, if I focus on a very close object, say, 1 foot, when I sweep away, everything stays blurry until I tap the screen to refocus.
It was my understanding that the X5 would auto focus as it was moved. Is this not correct?
Thanks,
Maury
2016-8-31
jcap858
Flight distance : 1949820 ft
You're talking about continuous focus. The X5 has auto focus where you tap on an area and then the camera focuses. But if you move and the object you were tracking changes in distance then you will be out of focus.
2016-8-31
maurymcc
jcap858 Posted at 2016-8-31 16:17
You're talking about continuous focus. The X5 has auto focus where you tap on an area and then the c ...
Yep, I am. Good grief, buyer's remorse. I love everything about the OSMO PRO setup *except* that it won't continuously focus. I didn't read/see that as I studied for purchase. Ugh. I would return it if I didn't have to destroy the boxes to get all the parts out...
2016-9-1
jcap858
That's one of the many features that users have been asking for but DJI has not gotten around to putting it into a firmware. DJI WHERE IS FOCUS PEAKING????
Anyways, there are ways to get around this.
1) If your filming in bright settings, set the aperture to a high F stop. That will cause most of what your filming to be in focus regardless of movement.
2) Practice using the focus bar on the app. Before I got the focus handwheel I was using this to adjust focus and getting decent results.
3) Buy the focus handwheel for the Osmo. I love this thing. Really easy to focus on objects and track. The only thing that is missing is focus peaking. I don't need continuous focus, because on other camera systems I have used at times the focus is on things that I don't want. However, with the Osmo mobile just being released, the app showed active tracking for it. So if we can get active tracking plus continuous focus for Osmo Pro users, now we are talking.
2016-9-1
fans49693779
Flight distance : 308619 ft
Longer communication cable for the focus wheel?
Considering the osmo pro as one of my company's options. Curious is there is an option for a longer communcation cable so I could mount the osmo pro on a z - axis while the focus wheel is on an extender arm closer the handle.
2017-1-18
