A3 EXT and LB settings
4005 20 2016-8-31
UAVServices
Flight distance : 756178 ft
Hi there, every time I close the DJI go app I have to go into the HD settings and change the option from LB to EXT.
Not only does this become anoying I belive it also hinders any third party apps from acessing the data from lightbridge.
Can you tell me if this will be fixed such that we can make this a permenant selection in the DJI Assistant 2 program perhaps?
Thank you.
2016-8-31
DJI-Jamie
Flight distance : 112405 ft
Can you please provide a list of your set up? Are you using a 3rd party app with the Go app?
2016-9-1
UAVServices
Hi there, thanks for the reply.
Here is the setup.
A3 flight control
Light bridge 2 with DJI TX
using all standard wiring harnass from A3 to LB and camera
Camera is DJI X3
motors are E1200
Quad
I am only using go app no other third party app is working unfortunately and I believe this EXT and LB setting would hamper their efforts.
I would test for you any software you wish and can be contacted direct at mail.uavs@gmail.com
We fly every day and test every day.
Steve
2016-9-1
UAVServices
To be honest if this could be set in the DJI Assistant 2 then the settings should be set permanently without worry of being over written by the apps.... just a thought but likely that is not easy
2016-9-1
UAVServices
Ok so I know I am not the only one with this issue.
Why is it so hard to get any sort of support out of DJI?
Seeing as we are all DJI beta testser I will report what I think on the issue and what I will try.
I "think" that if others are having luck with third party apps on the M600 and stand alone A3 with lightbridge have issues it could come down the the order the gear is powered up.
My guess is that LB is not seeing the camera attached because the camera does a song and dance before it outputs an HDMI signal to the LB2
Thus the LB2 decides it is going to be strictly used for an external HD transmission through the HDMI input.
If the camera was powered on and finished its song and dance by the time the LB2 had power and was looking for a HD video signal it would see this signal and stay on the EXT setting.
Quite possibly the m600 waits for the HD video feed (apparently it runs different firmware)
Can we just have the option to set the LB2 to EXT mode in the DJI Assistant 2 software? Then it won't get changed by the apps or LB on boot.
sigh... this will fall on more deaf ears but it makes me feel better to type it.
Steve
2016-9-3
UAVServices
The next thing to consider is that DJI has provided a separate camera firmware for the M600 which apparently we are to use for the A3
Possibly they are actually incompatible and causing issues.
2016-9-3
iSkyUnmannedSys
Flight distance : 7152087 ft
I've been having the same problem as others. PLUS 50% of the time on boot up the camera briefly connect (the camera setting appear for a short time) then they all change over to N/A. It's totally random too which is getting to be a terrible pain when on set. We can always tell when it's going to connect properly as the "The home point has been set, please check it on the map" plays.
I believe others are having the same problem on the M600 with this connection problem. Just wish DJI would sort this issue out asap.
My setup is S900/A3/LB2/X5R
2016-9-9
DronelyLtd
iSkyUnmannedSys Posted at 2016-9-9 12:42
I've been having the same problem as others. PLUS 50% of the time on boot up the camera briefly conn ...
What is your current work around for this?
We are going with the X5 and a FPV cam on top, so once thats all setup I will let you know if it makes a difference.
2016-9-9
iSkyUnmannedSys
Kris......:p
2016-9-9
DronelyLtd
Mark.........
2016-9-9
DJI-Jamie
UAVServices Posted at 2016-9-4 13:06
The next thing to consider is that DJI has provided a separate camera firmware for the M600 which ap ...
The M600's X3 upgrade file can be used when upgrading the X3 with an A3. The A3's main controller or it's M600 counterpart would not affect the camera's data package since they are the same encoding. If all the components are up to date with the latest firmware, that should help alleviate the reset in camera settings. To clarify, how have you been powering off the aircraft?
2016-9-12
UAVServices
I have the latest x3 firmware and this all still keeps happening
It means apps won't work in a3 stand alone I am sure
I have tried every order of unplugging and re plugging there is. Trust me, you can get it working even 7 times in a row then the next day 7 times it fails
Ext and lb setting needs to be done in assistant to remove this issue permanently
2016-9-13
DJI-Jamie
UAVServices Posted at 2016-9-14 01:59
It means apps won't work in a3 st ...
It's definitely a suggestion that I will pass to the appropriate department to see if it's possible to include a hard setting in the Lightbridge 2's Assistant Software.
2016-9-13
YOO SANG OH
Flight distance : 193294 ft
South Korea
iSkyUnmannedSys Posted at 2016-9-9 20:42
hi i have same problem with m600/ronin-mx/srw-60g/a7r
power on aircraft and RC
there are battery and aircraft information(no video)
(app setting
output-EXT
EXT 100% LB 0%)
then i power on ronin and a7r
there are no video too
and i switch app setting
(output EXT
EXT 90% LB10%)
battery and aircraft information are disapeared !!(no video too)
what's the solution??
2016-10-11
DJI-Jamie
YOO SANG OH Posted at 2016-10-12 13:57
I'm responding to you on your own thread.
2016-10-13
UAVServices
looks like this is mostly resolved.
2016-12-2
lt
Flight distance : 2516778 ft
South Africa
iSkyUnmannedSys Posted at 2016-9-9 03:42
I'm having the exact same issue with camera control disappearing. Setup is M600+RTK+X5 all upgraded to the new firmware. Had this problem out of the box! It's quite annoying because we use the setup for mapping missions and its like playing a lottery because we have to constantly restart the missions because of the disconnect
2017-1-7
iSkyUnmannedSys
lt Posted at 2017-1-7 12:04
This was fixed ages ago as you can see by the fate on the previous replies?
2017-1-8
fans6b2d72e4
Flight distance : 16821870 ft
What does LV mean on Dji log
2018-11-17
Roety
Flight distance : 38579 ft
UAVServices Posted at 2016-12-2 11:37
how was it resolved?
2023-7-21
djiuser_0uq3SIfIR2SV
Flight distance : 125 ft
Roety Posted at 2023-7-21 15:18
Right and ages ago ?? By the time stamp it was a month
1-24 16:46
