POWER X5
3338 31 2016-9-1
Juan carlos3
Flight distance : 31768 ft
I am installing an X5 + LB2 + A3 and voltage do not know what power the X5, someone can tell me something?
2016-9-1
DJI-Jamie
Flight distance : 112405 ft
Could you clarify what frame you are attempting to install this system on?
2016-9-1
Juan carlos3
I think that the picture is not significant, but is a Gryphon
2016-9-2
Juan carlos3
DJI-Jamie Posted at 2016-8-27 00:23
It can only work with the A3 when paired with Lightbridge 2 and the M600 X Mounting Kit.
what you say, means that the X 5 should not buy if you don't have the 600 Matrice
2016-9-2
DJI-Jamie
Juan carlos3 Posted at 2016-9-3 03:28
It can only work with the A3 when paired with Lightbridge 2 and  ...
The X mounting kit can be used in tandem with the X5, Lightbridge 2 and the A3 without the M600. In your case, however, potential modifications to the frame attachment may be needed. You should follow the instructions in the M600 manual for the proper cable and power connections.
2016-9-2
Juan carlos3
the fixing to the frame use the of the matrice 600 adapted, what not is specifies in any site is the range of voltage to feed the X5
the LB2 feeds you the X 5 to 12v, the retractable 2-6s, but the X5..
that is my doubt
2016-9-3
ricci2
Flight distance : 61158 ft
Hi Juan,
The x5 is connected direct to the LB2 and the gimbal takes its power from a common power rail on the M600, its not clear on the specs what the actual voltage is. I will measure it tomorrow and report back.
r
2016-9-3
Juan carlos3
Thanks ricci2
I try to ensure I if lipo 4s could feed the X5
2016-9-4
david.visagie
Flight distance : 158251 ft
South Africa
Hi Juan, i have the same setup also on a Gryphon frame, with a 6s battery setup, to be safe i installed a 12 volt 3A regulator, also very interested to know what the actual voltage it can handle and if it can be run directly from the 6S lipo on 25 volts, For now untill someone actually measures the voltage on a Matrice 600 to be safe run it through a regulator
2016-9-4
david.visagie
South Africa
ricci2 Posted at 2016-9-4 03:32
Hi Juan,
The x5 is connected direct to the LB2 and the gimbal takes its power from a common power ra ...
Hi Ricci2, Thanks also been looking for this measurement for a while
2016-9-4
Juan carlos3
6s, I rest assured that, by some site I haven't read something 18V. Which is not how much to 18v
The X5 feeds the LB2 to 12v, that also I have clear
I want to trust that it works with 4s, but connect and burn something I'm afraid
I apologize, but I am a coward
2016-9-4
Juan carlos3
David, una pregunta, que hace el HRT de la estación?
2016-9-4
ricci2
Hi,
These are the voltages as measured on the M600.
18v x5.
24v esc.
24v landing servo.
Since there is two voltages I expect there is a pmu device dropping the voltage.
Hope that helps.
2016-9-5
Juan carlos3
those voltages are good but...
X5 18     but there are people that leads to 12v with bec
24v ESC    If take 6s are 24v charged,21v to half load,already do not have 24v
24v landing servo     that works 3-6s
I think that they must have a range of work, but when you get off the battery would be below those voltages
2016-9-5
Juan carlos3
It rare dry not between nobody of DJI to clarify this issue, and to my by email nor I have said nothing
2016-9-5
ricci2
Fully charged battery on the M600 is 57v so plenty of scope to run for 35 mins using emu @ 24v.
r
2016-9-5
Juan carlos3
14s????????
2016-9-5
Juan carlos3
I guess that you proves to 4s, if 18v are recommended and there are people going has 12v, 4s anger well!
2016-9-5
Juan carlos3
I think that me talta the cable from positive, it can confirm someone
are the cables that van's X 5 to LB2  The LB2 does not have current
2016-9-8
david.visagie
South Africa
Juan carlos3 Posted at 2016-9-8 19:58
are the cables that van's X 5  ...
you are using the wrong cable for the Dbus input, it should be the one supplied with the A3 it has a red wire in the pin that you can see in this picture that is empty
2016-9-8
david.visagie
South Africa
there is no power from the X5 to LB2
2016-9-8
david.visagie
South Africa
ricci2 Posted at 2016-9-5 15:05
Hi,
18v x5.
Thanks for the info, I also found this in the M600manual
2016-9-8
david.visagie
South Africa
2016-9-8
david.visagie
South Africa
2016-9-8
Juan carlos3
The photos are no
tis blame of computer?
2016-9-8
Juan carlos3
david.visagie Posted at 2016-9-9 02:28
you are using the wrong cable for the Dbus input, it should be the one supplied with the A3 it has ...
Thank you has appeared the wire
2016-9-8
Juan carlos3
with 4S functions well, if not with 18v be faster
2016-9-19
fans3f39f9f6
DJI-Jamie Posted at 2016-9-2 20:11
Hi Jamie
Did you find out if the x5 can be run on a 6s battery
Thanks
Karl
2017-1-6
DJI-Jamie
fans3f39f9f6 Posted at 2017-1-6 06:49
Hi Jamie
Thanks
The X Mount can use a 18v - 26v 6S battery, if that's what you're referring to.
2017-1-6
ducpeter
Flight distance : 62175 ft
right X3/5 mount use 4-6S, we are using 6S from the XT60 connection on the S900/1000
2017-1-17
autopiloton
ducpeter Posted at 2017-1-17 11:59
Is this still working for you? I am going to use 6s to power my x3 mount. I just wanted to make sure your camera held up under 6s. Thanks very much.
2017-10-13
ducpeter
Yes still working with no problems on x3 and x5 with 6s
2017-11-19
