GoPro Black or Session Mount On OSMO Mobile
47190 28 2016-9-1
rVPKxki20zHP
Malaysia
Can anyone with the Mobile try and see if a GoPro can be mounted onto it, I was going to buy another Gimbal, but the Mobile iis about the same price so I thought.. why not?!
2016-9-1
DJI-Thor
Flight distance : 13602 ft
No, it can't, it needs the device to run Android or iOS to work.
*Edit: it actually can, you'll just lose some features.
2016-9-2
Marauderz
Malaysia
DJI-Thor Posted at 2016-9-3 15:10
If I just need it as a stabiization platform and not use any of the smart features?
2016-9-3
user06dd1e09d7
Dji Osmo mobile.. I had the same question and I got an answer from DJi, they confirmed that you can operate the Osmo mobile and it's not reliant on any App.  You can essentially mount a camera that is not app capable.
2016-9-4
DJI-Thor
Marauderz Posted at 2016-9-3 08:03
It actually can be used as a stabilization platform, as long as the thing is not too heavy, and has something that the clamp can clip onto(not too thick)
2016-9-4
DJI-Thor
user06dd1e09d7 Posted at 2016-9-4 13:35
Dji Osmo mobile.. I had the same question and I got an answer from DJi, they confirmed that you can  ...
You're right
2016-9-4
Marauderz
Malaysia
user06dd1e09d7 Posted at 2016-9-5 01:35
Also, you'd need to figure out how to balance it right? Good to know, time to get one and try it out!
2016-9-4
bleyten
http://www.thegimbalstore.com/pr ... e-for-evo-sp-gimbal
2016-9-7
twanvincken
I made a video with a DIY GoPro mount for the DJI OSMO MOBILE, it works!!
Check it out!
2016-9-22
m.ksunchik
Flight distance : 43002 ft
twanvincken@zig Posted at 2016-9-22 22:07
Check it out!
https://yout ...
Great job! Thanks for posting!!
Does dji Osmo horizontal axis motor get in GoPro wide lens field of view?
Please upload the video from GoPro on dji Osmo mobile.
2016-9-22
zoti
Flight distance : 101526 ft
I got you covered.
2016-9-28
zoti
The GoPro is mounted facing you but you can turn the Osmo 180 degrees and it works fine.
2016-9-28
lourensvanrooye
South Africa
Hi Guys,
I also made a mold/mount out of foam for my action cam. I can use it as a front facing cam without the gimbal being in the shot.
2016-10-11
stavrossid
Flight distance : 334570 ft
Greece
http://www.ebay.com/itm/gopro-Adapter-switch-mount-For-DJI-osmo-mobile-gimbal-Zhiyun-Z1-Smooth-3-axis-/262638464342?hash=item3d2678ed56:g:spYAAOSwLnBX5KnZ
Our Asian friends already thought for us!
2016-10-12
vivian
Flight distance : 661627 ft
India
Like what feature will it lose ?
I need for motion time lapse.
Can GoPro with Osmo Mobile let it happen ?
2016-12-9
cderrington
Flight distance : 621798 ft
vivian Posted at 2016-12-9 06:32
Motion time lapse is one of the features you lose by not using the Osmo Mobile with a phone.
2016-12-9
TitanFlyer
I whipped one up real quick on tinkercad. Still have to print and test but it generally is just an iphone model with a session mount stuck on it.
Once I have it fixed up I will post a link.
2016-12-27
fans52c1a8f1
cderrington Posted at 2016-12-9 10:14
So you can't stick the gopro where the phone would go on the gimbal and then use the app to control the gimbal? The phone has to physically be on the gimbal in order for all the features to work?
2017-1-3
Tan.gaikkuen
Malaysia
I tried to use the apps while the phone is not mounted and with the gopro mounted on the osmo mobile instead.. n managed to go motion time lapse with the gopro.. one thing i still can't figure out is how to use gopro on osmo mobile smoothly.. the gimbal motor tends to overwork n vibrate hard at certain time or at certain position when mounted with a gopro.. doesn't happen when using with my phone
2017-1-14
giggidditygiggi
Tan.gaikkuen Posted at 2017-1-14 10:35
Overwork and vibrate means the camera is not balanced and will eventually get hot and fail (blinking yellow light).
You just need to figure out how to balance it before turning it on (with counterweights - like the earlier samples using a AA-battery or two) once it is leveled turn it on and it shouldn't feel hot or overwork the motors.
2017-1-14
yelenavik
giggidditygiggi Posted at 2017-1-14 22:26
on ebay sell many from $9-$15 with weigt balancing for go pro, acceptable for any action camera
2017-1-14
fansebeed138
Here you go.  https://www.amazon.com/gouduoduo ... mo+mobile+for+gopro
2017-1-16
Viper989
Flight distance : 891194 ft
fansebeed138 Posted at 2017-1-16 10:31
Here you go.  https://www.amazon.com/gouduoduo2018-Adapter-Z1-Smooth-handheld-accessories/dp/B01LYX4ELR/ref=sr_1_1?ie=UTF8&qid=1484591395&sr=8-1&keywords=osmo+mobile+for+gopro
That is the one i got .
Had to modify it to use with my SJ5000x . Works perfectly . Event had it to work with 2 SJCam for side by side comparison
2017-1-16
hitmee
Singapore
here is an adapter for gopro hero 5
2017-1-16
info534
For UK users, I bought this for my Hero 3+. It works well but you cannot use it on super-wide angle as you will find the Osmo in frame.
2017-1-18
user3f044d71f4
Romania
But, you can make motion time lapse, or timelapse with the gopro mounted on the osmo mobile?
2017-2-12
Solublepeter
info534 Posted at 2017-1-18 01:27
To avoid this, use the Osmo in Torch mode, then the motor shouldnt be visible
2018-3-15
Solublepeter
user3f044d71f4 Posted at 2017-2-12 01:44
Yes, that would work
2018-3-15
Pool187
Hello,
Has anyone found a great adapter for go pro sessions? one last thing, when you use your go pro with the osmo mobile2, do you use it facing you and then turn all the osmo to resume forward? or do you put the pro that looks directly to the outside?
Let me know what you think
2018-10-29
