F550 Build Gain Settings?
17575 17 2015-1-29
raiedzeidan.ema
Flight distance : 755033 ft
My F550 kit will be in today! Super excited to build it! Does the Naza MV2 come with default Gain Settings for a Hex? Are these good settings to start with?
2015-1-29
raiedzeidan.ema
Found some stuff via another post sorry!
http://download.dji-innovations. ... _Guide_v1.26_en.pdf
2015-1-29
alansworld.gmai
Flight distance : 27434 ft
F550, Naza M V2 as well.  Straight out of the box my gains were 125 255 244 130 140 140.  Through a lengthy trial and error process I'm currently at 180 180 140 90 140 140.
Everything seems fine now (as I recall - no flying for 7 weeks, weather in UK).  The trickiest to get right has been the 4th, Vertical.  Last time I flew it was on 100, but showed a desire to descend, so I've moved to 90, though untested at the moment.
Comparing my current setting and the out of the box settings, you can see how far out the original values were.  255 and 244 are lunatic!
I hope you have a ball building it.  I loved every moment of tinkering.
2015-1-30
DJI-Dave
The default gain setting are a good starting point.
2015-6-17
DJI-Dave
For the F550 they are 170 170 150 140 170 170
2015-6-17
DJI-Dave
alansworld.gmai Posted at 2015-1-30 18:26
F550, Naza M V2 as well.  Straight out of the box my gains were 125 255 244 130 140 140.  Through a  ...
Not sure where you got 255 and 244 from?
2015-6-17
alansworld
DJI-Dave Posted at 2015-6-18 07:30
Not sue where you got 255 and 244 from?
As I said, out of the box.  Before I touched anything at all that's what the gains were.
2015-6-18
DJI-Dave
alansworld@gmai Posted at 2015-6-18 16:09
Ok, so who ever you bought from must have adjusted the gains, because a brand new Naza V2 does not come with gains set like that.
2015-6-18
alansworld
DJI-Dave Posted at 2015-6-19 06:36
Ok, so who ever you bought from must have adjusted the gains, because a brand new Naza V2 does not ...
Reputable dealer in the UK.  All brand new.  Original DJI box seals (everything in the kit) intact and untouched.
2015-6-19
DJI-Dave
alansworld@gmai Posted at 2015-6-19 16:03
Reputable dealer in the UK.  All brand new.  Original DJI box seals (everything in the kit) intact ...
Wow that is strange! I have set up a lot of brand new Naza V1 and V2 and I have never seen gains like that.
I have also never head of it on any RC forums.
But now I have.
2015-6-19
knarfboy
Flight distance : 494508 ft
@ DJI-Dave
I have a F550 with E310 and A2 , what gain settings  i have to use?
more pictures : http://www.drohnen-forum.de/inde ... tID=52448#post52448
2015-6-24
superkresh
For the basic:
pitch: 30%
roll: 30%
yaw: 50%
For the attitude:
pitch: 150%
roll: 150%
For the vertical it depends on how heavy is your drone. Good point to start is 100%.
2015-6-25
DJI-Dave
knarfboy Posted at 2015-6-25 07:13
@ DJI-Dave
Your F550 looks great!
There is no one size fits all for gains settings. Too many variables. You will need to start with defaults and then adjust to your particular craft.
Here is our wiki info on gains and gains tuning.
This should help.
Please read.
http://wiki.dji.com/en/index.php/Gains_Setting
2015-6-30
Dominique
Belgium
DJI-Dave Posted at 2015-6-30 16:14
There is no one size fits all for gains settings. Too many variables. Yo ...
Hello,
I have equiped my F550 with new E300 + new esc and I am looking now for the new gains I should use with this equipement :
4s5000, gopro 3+, gimbal H3-3D, ios, weight about 2.4 kg
for a smooth flight.
I found different kind of gain settings, but I don't know which I should try first.
Those ares the gains I found :
120 120 80 130
100 100
170 170 170 170
180 180
DJI basic gains setting are :
140 140 90 95
150 150
180 180 140 90
140 140
170 170 150 140
170 170
Thanks for sharing your experience.
Dominique
2015-7-30
DJI-Dave
Try
120 120 80 130
100 100
2015-8-9
rjhirsch
Need help.
Just finished building a F550 with the following hardware:
Naza M V2 with GPS
Can Bus Hub,
Mini OSD,
Gopro Hero 3+
H3- 3 D gimbal
Fat Shark 600TV Line camera for FPV
AeroXcraft lancing Gear
New E310 Motors and Speed Controls
All up weight without Battery is around 1975 grams
Two questions:
What battery would give me at least 12 minutes or more of flight time?
What are the recommended gain settings for this configuration?
I have a New Thunder Power G6 4 cell 3900 ma 25C that weighs 356 grams. Not sure what flight
times I will get or if I should run 2 in parallel.
Thanks.
Ron
2015-8-10
DJI-Dave
rjhirsch@charte Posted at 2015-8-10 23:44
Need help.
Naza M V2 with GPS
A 4cell 6600mAh will get you about 12 min.
See above post with wiki link about gains.
2015-8-11
lasuncion
Guam
i bought the f550 kit with h33d and i use a gopro 3+ and 4s 5200mah batt. what gains should i use? TIA
2016-8-25
