Mavic - Anatel
6421 11 2016-10-11
ligJHAXOjhx3
Flight distance : 610988 ft
Can someone tell me if the Mavic is Anatel certified already? if it is it must present the Anatel logo and licensee number in its tag attached at the drone and the controler.
In much appreciate the feed back
2016-10-11
Lepus
If you have any other Drone from DJI that has that same certification, then the Mavic will probably have it or be certified.  If there are no other Drones from DJI with that certification then they probably will not.  You might want to take your question to pre-sales and ask them.
2016-10-11
AlexW
Flight distance : 1981043 ft
I am also looking for this answer, if someone has a Mavic would you kindly look to find in the body if they come with logo "ANATEL" Brazilian certification (FCC similar) ?
Thank you
2016-12-26
DJI-Ken
Flight distance : 1515312 ft
Lepus Posted at 2016-10-11 15:33
The label inside is CMIT and FCC.
2016-12-26
DJI-Ken
AlexW Posted at 2016-12-26 10:53
Thank you
See above post.
2016-12-26
fansea27ec94
Brazil
Hi!
The Mavic is ANATEL certfied, it has the seal on the product tag in the battery compartment with the authorization number 04036-16-07248. The official documents are here as well if needed : https://fccid.io/ANATEL/04036-16 ... 2-A273-56D7D0FA3976
Cheers!
2017-4-19
fans1ef695bc
Flight distance : 178442 ft
Argentina
fansea27ec94 Posted at 2017-4-19 09:01
Hi!
The Mavic is ANATEL certfied, it has the seal on the product tag in the battery compartment with the authorization number 04036-16-07248. The official documents are here as well if needed : https://fccid.io/ANATEL/04036-16-07248/Certificado-de-Conformidade-T%C3%A9cnica/B3E3D53B-6325-4EA2-A273-56D7D0FA3976
Hi! I bought my Mavic in USA and live in Argentina. It is ok to enter Brazil with this document?
2017-11-27
Eduardo0
Flight distance : 6443990 ft
Brazil
DJI-Ken Posted at 2016-12-26 10:01
Mine has the ANATEL logo in both the drone and the Mavic.
2017-11-27
fans1ef695bc
Argentina
Eduardo0 Posted at 2017-11-27 04:57
Eduardo, this means that Mavic is already homologated by ANATEL? Mine has the ANATEL logo too, but I'm flying from Argentina next month and like to know if the logo is good enough or do I need to do any other thing with ANATEL office.
2017-11-30
DocAraxá
Flight distance : 202283 ft
Brazil
fans1ef695bc Posted at 2017-11-30 07:41
If your drone has the label, you are ok.
Mavic is the only drone that is imported with ANATEl label.
Others, you have to pay for it!
Another certification you should consider is the ANAC certification, that is specific to you and your bird.
2017-11-30
CRHassan
DocAraxá Posted at 2017-11-30 08:19
I Just bought mine in the USA and it doesn't have the ANATEL logo. Do I have to print the logo with that authorization number mentioned above to stick on the drone or do I have to do a brand new authorization with ANATEL?
2018-5-24
DocAraxá
Brazil
CRHassan Posted at 2018-5-24 08:05
You must have a ANATEL certification.
Otherwise you could have your drone confiscated as you enter Brazil, by board officers.
2018-5-25
