M100 GPS Mounting Default Position X Y Z
1187 2 2016-10-18
davidherries
Flight distance : 3768451 ft
New Zealand
Hi
Just wondering what everyone has been using for the default GPS mounting position for the M100 (as per manual stork mounting on right side of top plate)?
If i click default or reset in the DJI Assistant 2 i get
X 25mm
Y 30mm
Z-120mm
Do these setting seem right for this position ? I would have thought the Y position would have been a little more to the right?
Also does anyone have problems keeping custom mounting XYZ settings.   If i change them and then restart the M100 and load DJI Assistant and reconnect the default settings again are displayed?
Thanks in advance.
Dave
2016-10-18
DJI-Jamie
Flight distance : 112405 ft
To clarify, what version of the Assistant do you have? Are you using a Mac or PC?
2016-10-20
davidherries
New Zealand
For this error storing the changed settings I was using a Window 10 PC, and using a Assistant V1.0.4.   I have updated to V1.0.5 and this storing issue has been resolved.
I am still confused on what the default GPS location settings should be for the standard configuration on the Matrice 100.
Thanks in advance.
Kind Regards
Dave
2016-11-1
