New firmware for Mavic Pro has been released(04/05/2017)
310050 1665 2016-10-21
fans95824758
Flight distance : 994216 ft
Bill in Ohio Posted at 2017-5-4 11:01
Monday this week got an update to Android OS 7.0 (I thought it said 7.0.1) and I have flown 4 full flights using photo, video, active track, POI, and tap fly.  Everything worked as advertised and flew down to low battery before bringing the Mavic back.  Also did a flight where I tried RTH and how to stop RTH.  Everything worked as described in the manual.
Mavic Firmware v01.03.6600; DJI GO4 app v 4.0.6; Samsung S7 with android 7.0.  (settings >
Hi, thank you for your answer. I download firmware to .550 and my Mavic has flown ok  again, 300 meters distance without losing signal. I don´t rely on .600.
2017-5-5
randy.sauder
Flight distance : 872572 ft
Irmantast Posted at 2017-4-23 08:47
Why first post is not updated with Firmware : v01.03.0600 version?  It means update is not ready or what?
I've asked that question as well. Seems odd that admins temporarily / stopped being the ones to post that thread...
2017-5-5
randy.sauder
I think DJI have changed the meaning of FW....it now officially means "Fiddle-With"
2017-5-5
Bill in Ohio
fans95824758 Posted at 2017-5-5 06:32
Thanks for your info.  However I was fine until .50 and then .550 was no better, and .6 was a fair amount better.  The update to android operating system 7.0 didn't help any, but the update to 7.0 on May 1 2017 seems to have done the trick.  Again I only got 4 flights in flew down to low battery warning each time without incident is very encouraging.  Whenever the weather cooperates, I will fly more.
2017-5-5
Bill in Ohio
randy.sauder Posted at 2017-5-5 08:05
The update is available through DJI Assistant or through the dji go4 app.  You should be getting a version doesn't match error.  If not sure you have it, you can check in the app menu under general settings last item is about.  You have to be connected to controller and drone.  Or you can use DJI Assistant by connecting the computers USB port to the Mavic USB port on the side and turn the controller on if you want to update it at the same time.
Select your Mavic and you will see list of firmware updates, pick the one you want or refresh to reinstall.
There is a dji video tutorial on this, as well as in the manual.
2017-5-5
Hasher
Denmark
I am starting to regret  buying Mavic because of the Firmware update.!! i updated the firmware using my laptop and every time i use my mobile, it tells me i have to update the firmware again. and when i try to update it , it tells me i dont have internet connection.!!! which is not true. i have reinstall the app and restart my laptop. nothing helps. i have used all the morning trying to update it through the mobile as well. but i doesnt work. 3 of my battery drained and still no update!!! it takes the fun out of the day. i was really looking forward to do some video today , but i dont think this will happen.!!
2017-5-6
Exeleon
Hasher Posted at 2017-5-6 04:55
If what you describe is occurring as a result of attempting to install .600, you are definitely not alone. Revert your RC and AC back to .550 and sit tight until a new (subsequent to .600) firmware is released.
2017-5-6
NE.UK
Flight distance : 25371 ft
.600 is giving me a upgrade failed message, it seems that the Remote Control updates but the Air Craft does not.
I contacted support and they told me to send it in after the upgrade failed again.  If you have this problem  try the following (downgrade to 550)
Use DJI Assist 2 (PC or Mac Application)
Hardwire drone to PC/MAC, load DJI assist 2 application and then do a factory reset (factory reset may be unsuccessful for the RC but still continue)
Downgrade to the oldest version of the firmware
then upgrade to .550
Do the same with the controller
Make sure you do the upgrade for the AC and RC separately
if at any point the upgrade failed then turn the device off and on, exit DJI assist app and start again
This will get you to FW .550
Im not sure whether DJI still want me to send it in for repair, but I'll contact them tomorrow, unless someone comes back to me on this thread.
2017-5-6
NE.UK
James from technical support has confirmed I do not need to send the drone in and should use .550 until the next version comes out (bypass .600). If anyone from DJI thinks otherwise please let us know on this forum (pretty much what Exeleon said)
2017-5-8
jerome42
Flight distance : 10617 ft
The firmware 600 is full of bugs (NFZ limit) if you can't upgrade it's not a problem.
2017-5-8
Tombolian
Flight distance : 675958 ft
Wow, what a weekend.  With my Mavic Pro arriving on Saturday, I spent the better portion of the weekend in this firmware 'trap'... To all of the other new users having problems with the firmware update, .0550 is the ticket (at least it was for me).  Reading about having to send my Mavic back to DJI was discouraging to say the least, my eagle eyes are awaiting the post-.0600 version... @NE-UK, thanks for all of your efforts in here!   James from Technical support, I don't know you, but I think I love you...
2017-5-8
trica de
Flight distance : 1062090 ft
*.700 is up - no changelog so far
2017-5-8
NE.UK
trica de Posted at 2017-5-8 21:57
I might be brave and try to update, the sensible thing to do of course is to sit tight and wait for the feedback of other peoples experiences and also the change log update.
2017-5-8
Fistworthy
Flight distance : 1613953 ft
Anything will be better than .0600 for me. I get NFZ and ATTI warnings, and a very uneven gimbal.
2017-5-8
x1m0x
Belgium
.700 still fails, couldnt upgraDe to .600 and now .700 same thing
please move discussion here
http://forum.dji.com/forum.php?m ... mp;page=1#pid791364
2017-5-9
fansfba4de80
Flight distance : 249967 ft
South Africa
.0700 Release Notes:
Added support for DJI Goggles.
Optimized gimbal self checking.
2017-5-16
fans575b3df7
I got my Mav in November, I believe.
I only updated the firmware around then.
Question: To get every improvement from every f.w. upgrade, do I have to upload each upgrade and in order, or will simply uploading the latest give me everything?
BIG Thanks!
2017-5-20
DJI-Thor
Flight distance : 13602 ft
fans575b3df7 Posted at 2017-5-20 14:49
Just simply upgrade to the latest one.
2017-5-22
Lars997
@DJI-Thor:
Hi Thor, I also have the problem not being able to install .700. May you kindly give me access to .350 and I will try the advised path of downgrade/upgrade. Thanks, Lars
2017-5-25
trica de
are we back to version Firmware : v01.03.0550 ???? I can remember there was a 700 out ...
2017-5-26
DJI-Thor
Lars997 Posted at 2017-5-25 23:55
@DJI-Thor:
Please PM me your DJI Account email~  Thank you in advance.
2017-5-27
davviddd
Banned
Ukraine
2017-6-15
PANOIO
Flight distance : 2206447 ft
Portugal
DJI-Thor Posted at 2017-5-22 02:57
After trying to update dji mavic pro remote control firmware, the update failed, now the remote contro says that the firmware version is v00.00.0000 and I can not update or restore it
2017-7-20
thideluis
Flight distance : 111785 ft
Brazil
PANOIO Posted at 2017-7-20 05:32
I have the same problem but on the aircraft.
2017-7-29
fans4c6a9621
Flight distance : 794 ft
Still cannot update my drone
2017-9-26
DJI Thor
fans4c6a9621 Posted at 2017-9-26 08:17
Is there an error message when upgrading? If yes, what is it?
2017-9-28
