pinpointmapping
Flight distance : 5345105 ft
You may be able to use the Video stream with some software from ESRI called FMV (Full Motion Video)
http://www.esri.com/products/arc ... y/full-motion-video
Or you could take multiple still images (you could do frame grabs from the Video, but even 4k video isn't as good as a 12mp still) and use either Drone2Map (another ESRI product) or just use Pix4D to process the images (the concept is called Structure from Motion) and create a high resolution 3d model that would allow for accurate measurements.... Let me know if you need more info to get started. It helps if you have an understanding of GIS.... |
