Got My MAVIC Pro! Here is a sample of the 4K :)
12Next >
4651 61 2016-10-25
MavicPro4K
Share and Like! This is in Utah near Provo (BYU)
2016-10-25
qMvQTfjUrm4z
Beautiful!  How was the battery life?
2016-10-25
qMvQTfjUrm4z
Also, I see a lot of lense flare, especially at 3:49.  Did you have the gimbal guard on?
2016-10-25
Nees
Flight distance : 80991 ft
Belgium
There is something strange with that footage. Left side is crisp/sharp, right side is blurry. Protective dome? Still has plastic on the lens?
2016-10-25
qMvQTfjUrm4z
Nees Posted at 2016-10-25 16:02
There is something strange with that footage. Left side is crisp/sharp, right side is blurry. Protec ...
I just noticed that same thing too, especially in the last 2 minutes.
2016-10-25
Frank I.
same here, i hope it's "just" the protective cover being on that's causing this blurriness on the right side and the flares.
The left side looks amazing though, and colors also look fine. Thanks for sharing!
...other than that, i wouldn't dare flying over streets with cars, parking lots and other people's houses -
even if it's permitted where you live (i don't know). Just seems a pretty bad idea to me...
2016-10-25
MavicPro4K
The right side is due to the sun directly hitting it from the Right Side. In my 2nd video this didn't occur.
2016-10-25
MavicPro4K
qMvQTfjUrm4z Posted at 2016-10-25 16:53
It's solid. Didn't try to fly more than 15 minutes though
2016-10-25
Ben Ditto
Flight distance : 239491 ft
Portugal
Sorry to tell you mate, but you have an decentered lens.
2016-10-25
Tahoe Ed
Flight distance : 41668330 ft
The flare on the right was noted when we were testing with the protective cover left on.  The OP says it was off.  Note that DJI and others will have ND filters available which will also help.
2016-10-25
Delta Nine
Yeah the right is not focused properly in the 2nd half of the video for some reason.
2016-10-25
MavicPro4K
Does updating the Firmware fix anything? I didn't update the Firmware before flight.
2016-10-25
Tahoe Ed
We have tap to focus with center weighting.  We also have the option to do manual focus.  We don't know what was done or how the camera was set up.  It is odd that it was focused on one side.  If it was focused on the right side and then moved  it could make that happen.  We need more information.
2016-10-25
MavicPro4K
The right side has the sun hitting it from the top. Would this be the cause? My 2nd video doesn't have any issues --- I didn't point it towards the sun.
2016-10-25
Delta Nine
Pause the video at 5:50, you are pointing away from the sun. Lokk at the four houses in the foreground, the one to the left are in focus, but houses to the right are blurry.
2016-10-25
Delta Nine
Lets see the 2nd video.
2016-10-25
dropbars
Well, if he doesn't have the plastic guard mounted, we maybe seeing the first RMA for the Mavic. Lol.
That would suck. You're one of the first to get it but you are also the first to have to send it in for repair.
2016-10-25
Ange1walk
Flight distance : 30305 ft
dropbars Posted at 2016-10-26 08:19
Well, if he doesn't have the plastic guard mounted, we maybe seeing the first RMA for the Mavic. Lol ...
He isn't the first, there is a guy with a lost screw inside the Mavic and possibly a guy with a broken Gimbal.
2016-10-25
hallmark007
Flight distance : 9827923 ft
MavicPro4K Posted at 2016-10-26 00:52
The right side is due to the sun directly hitting it from the Right Side. In my 2nd video this didn' ...
Good job thanks for showing your first test flight, enjoy and safe flying, my daughter works for a company fro Utah.
2016-10-25
Fulgerite
Left half of the video is in focus.  Right half of the video is out of focus.  The sensor or lens is mis-aligned.  This camera is malfunctioning.
2016-10-25
Zc4nW8WAYWvI
Ange1walk Posted at 2016-10-25 17:24
He isn't the first, there is a guy with a lost screw inside the Mavic and possibly a guy with a br ...
"Broken gimbal guy" has his Mavic sitting on deep carpet...  He didn't respond back after it was suggested to put it on a table.
2016-10-25
stratosHD
Flight distance : 1231280 ft
you town is beautiful
2016-10-25
Frank I.
it has nothing to do with sun angle, left side is sharp and right side soft throughout the entire clip. (stop at 0:08 and 0:19)
If the lens cap really was off (where did you state that?) it's either a misaligned lens or an issue with stabilizing the gimbal.
Lens misalignment would be bad, that's a hardware thing - given how small that cam & gimble are you'll unlikely be able to fix that yourself.
If it's a stabilizing issue, it could(!) be cured with a firmware update. So i hope for you it is the latter.
(putting on an ND filter will certainly not help - no matter whether it turns out to be a misaligned lens or SW problem.)
Thinking about it... i really hope the DJI techs designed the stabilization SW with possible ND filters attached in mind...keeping my fingers crossed! ;)
2016-10-25
Ange1walk
Zc4nW8WAYWvI Posted at 2016-10-26 08:34
"Broken gimbal guy" has his Mavic sitting on deep carpet...  He didn't respond back after it was s ...
Yeah i suggested to him to put it on a table, but that's why i said "possibly"
2016-10-25
Petroboy
Flight distance : 3681 ft
I'm sure the focusing issue will get figured out.  To me, besides the great looking landscapes, what struck me the most was the absolute rock-solid stability of the camera at all altitudes.  Absolutely beautifully smooth!
2016-10-25
jvanderhoff
Flight distance : 14045 ft
The stability is unreal. Very excited to get one of these in the future.
2016-10-25
MavicPro4K
Thanks! It's Provo Utah -- great scenery around here.
I'm updating firmware now as we speak.
2016-10-25
lkgm0vitOBiu
Its probably condensation on the lens
2016-10-25
MavicPro4K
HERE IS THE 2ND VIDEO - NO BLUR AT ALL
I CLICKED AND TAPPED FOCUS ON THE PREVIOUS VIDEO (ON THE LEFT)... I believe this was the reason why. As you can see no ISSUE with the MAVIC here!!
2016-10-25
agentbb007
Awesome video I live in Draper on Sun Crest. I ordered the fly more combo. Maybe we can meet half way when my mavic arrives.
2016-10-25
MavicPro4K
Cool!! That's awesome
2016-10-25
Petroboy
MavicPro4K Posted at 2016-10-25 23:10
I CLICKED AND TAPPED FOCUS ON THE PREVIOUS VIDEO (ON THE LEF ...
So on the second video, did you tap to focus in the middle of the picture?  I haven't received my Mavic yet so I have lots of time to gather tidbits of info .... such as where to tap to focus.
2016-10-25
MavicPro4K
No i just didn't tap anything. It focused by itself.
2016-10-25
elefantastico
Could it be a bit of Grease or fingerprints on the camera what produced the results of the First video? Did you clean the camera after the First video?
2016-10-25
MavicPro4K
I didn't clean it - like I said, I clicked to focus on my iphone which most likely caused the issue in the 1st video.
2016-10-25
hepnotic
Beautiful area. But im curious about its max range in the real world.
2016-10-25
MavicPro4K
? That was the real world...
2016-10-25
Free Bird
I was impressed how the Mavic transitioned from light into shade. I'm going too really enjoy using my Mavic on my photo trips. Thanks for sharing.
2016-10-25
cruxiaer
MavicPro4K Posted at 2016-10-26 13:59
He meant flight distance in the real world.
2016-10-25
Exib
Flight distance : 153760 ft
Was surprised to see the left prop visible at the start of your video  (video 2)
2016-10-25
12Next >
