SERIOUS BUG!
12Next >
3532 44 2016-10-27
Fulgerite
Dear DJI.  Please watch this video and FIX this BUG.  Thank You.
2016-10-27
ecophobic
All these various issues coming out making me a bit pleased that the seller cancelled my order. At least for now.
2016-10-27
hallmark007
Flight distance : 9827923 ft
Is it a bug or is it a hardware problem,
2016-10-27
Fulgerite
hallmark007 Posted at 2016-10-27 16:03
Almost certainly a software bug.  It just looks like the analog stick position is being ignored while the program is off stuck in some other loop. I am almost certain it's NOT a hardware issue.
After owning several Phantom drones...  This is pretty typical stuff.  DJI always has some glitches with early launch software.  They will fix it if enough owners post detailed videos showing the issues.  Eventually they get it right.
2016-10-27
civeng123
I guess you don't think the three other threads with this video are enough huh?
2016-10-27
fraser
Flight distance : 50003 ft
Looks like maybe just a visual bug in the software since it shows 0% despite being far outside the deadzone at center.
2016-10-27
Fulgerite
civeng123 Posted at 2016-10-27 16:06
Nope.  Not for a serious issue like this one.
2016-10-27
dana5
Flight distance : 14354 ft
This same video was posted in another thread.
I do not think this is a cause for concern, and here's why...
Notice that the eight ball gets stuck, BUT the numbers (the actual reading of the stick position) goes back to zero. I think you are looking at nothing more than a display bug in the DJI GO app, on the diagnostic screen. I do not think what you are seeing is related to any of the recent crashes.
2016-10-27
method007
Flight distance : 110449 ft
I'm not so certain that's a huge deal.  Looks like the image is freezing but it's still centering.  My PC does that when I calibrate my Xbox 360 controller.
2016-10-27
Tahoe Ed
Flight distance : 41668330 ft
We have documented two of the above issues, that is all.  We are working wih the users for a resolution.  It is not global issue.
2016-10-27
Nees
Flight distance : 80991 ft
Belgium
Tahoe Ed Posted at 2016-10-28 01:21
We have documented two of the above issues, that is all.  We are working wih the users for a resolut ...
Seen it already on 4 users from this forum... And how many here have one? :s
2016-10-27
hallmark007
Fulgerite Posted at 2016-10-28 00:05
Almost certainly a software bug.  It just looks like the analog stick position is being ignored whi ...
Makes me pleased I have to wait awhile,
2016-10-27
Fulgerite
Tahoe Ed Posted at 2016-10-27 16:21
Great.  Glad to hear it.
I am sure you guys will get to the bottom of it and find a solution soon.
Thank you.
2016-10-27
Jake Phantom 3
Flight distance : 2639747 ft
It's not a global issue because the Mavic hasn't been delivered globally.
2016-10-27
Fulgerite
Jake Phantom 3  Posted at 2016-10-27 16:59
I think he means it's not affecting all customers?  Only isolated cases?
2016-10-27
spope
So, should we ground our Mavic's until we better understand this? This would explain the spinning without remote inputs
2016-10-27
Fulgerite
spope Posted at 2016-10-27 17:07
So, should we ground our Mavic's until we better understand this? This would explain the spinning wi ...
Honestly...  After owning a P2 and a P3... If I saw a bug like this being reported... I would not fly until the next firmware update and look for other owners confirming it's safe to fly again.  But that's just me.  Others will disagree.
2016-10-27
HFI
Flight distance : 904990 ft
It looks like a graphical issue with the dot and not the actual reading. All the readings still show 0% when the stick is in the middle.
2016-10-27
Ben Ditto
Flight distance : 239491 ft
Portugal
Tahoe Ed Posted at 2016-10-28 07:21
With about the 50 drones that DJI has shipped worldwide 2 users is a considerable 4%.
2016-10-27
Fulgerite
HFI Posted at 2016-10-27 17:12
It looks like a graphical issue with the dot and not the actual reading. All the readings still show ...
I would agree except for the couple of owners reporting crashes where the drone started spinning out of control and crashing.  It may be related.  It may not.  But I do think it's probable that there are still a few bugs to be worked out.  And all the feedback we can throw at them (With detailed videos.) will help.
2016-10-27
spope
Yes I am going to ground my Mavic until we get a fix... Just too many goofy things popping up on the first Mavic's out in the wild.
2016-10-27
HFI
Fulgerite Posted at 2016-10-28 08:14
I would agree except for the couple of owners reporting crashes where the drone started spinning ou ...
Yep I agree with that. Anything to make sure this thing doesn't crap its pants ( when I get a replacement )
2016-10-27
quanthonytrang
Flight distance : 419980 ft
Maybe do the stick calibration slowly and let the screen register the movements.
Its a stick calibration, so it only needs to know where the max and centre positions.
2016-10-27
stealle
Flight distance : 21827 ft
If I had a Mavic, I doubt I would let much of anything stop me from flying... as long as I knew I could run to the store and buy another off the shelf. So, BE CAREFUL! You won't get another one anytime soon.
2016-10-27
nssd70ace
Flight distance : 612858 ft
I did a recalibration of my controller this evening. About to grab the controller and check if it was reading zero when the dot was not center. I do believe several times it showed a percentage. I'll film it and post it to YouTube if it shows an issue.
I am one of the first few to say I had this issue.
2016-10-27
Lepus
The way he let go, it almost seems as if the control is actually seeing the stick in that position, could it be some of that Mavic powder in there?  If anyone has it, best way to see if yours does the same is do the same calibration.
2016-10-27
nssd70ace
Just filmed a calibration and moving the sticks. The dot would get stuck in various positions but showed no values. If weather is good tomorrow evening I'll do another flight at the local soccer fields. I've only flown it once to test after the initial issue. Flew for 5 min roughly perfectly fine.
2016-10-27
Fulgerite
quanthonytrang Posted at 2016-10-27 17:28
Its a stick calib ...
That does not explain the behavior in the video.  The stick simply stops responding to input at times.
2016-10-27
Fulgerite
nssd70ace@yahoo Posted at 2016-10-27 17:42
I did a recalibration of my controller this evening. About to grab the controller and check if it wa ...
Post detailed video.  This helps the engineers.
Also be sure to note your firmware/software versions.
2016-10-27
baychilla
That would be my question.
2016-10-27
Fulgerite
nssd70ace@yahoo Posted at 2016-10-27 17:55
Just filmed a calibration and moving the sticks. The dot would get stuck in various positions but sh ...
Good to hear you had a safe flight.
2016-10-27
civeng123
Fulgerite Posted at 2016-10-27 21:07
You guys may be better served discussing this in the original thread so that info isn't spread all over the place.
2016-10-27
Fulgerite
civeng123 Posted at 2016-10-27 18:10
You guys may be better served discussing this in the original thread so that info isn't spread all ...
Right.  We would not want anyone to read about a perfect, safe flight. Right?  ;-)
2016-10-27
Z1uKtCi5N1Ix
that's like 50% of Mavics that have shipped out.
2016-10-27
civeng123
Fulgerite Posted at 2016-10-27 21:15
That was not my intent. I just figured having the discussion about the problem may be better all in one place, so info isn't spread all over the place.
The title of that thread is CRASH with DJI Mavic Pro today
2016-10-27
Fulgerite
civeng123 Posted at 2016-10-27 18:29
That was not my intent. I just figured having the discussion about the problem may be better all in ...
We are talking about how erratic stick readings might be related to crashes.  It's HIGHLY relevant to the subject of this thread and all crash threads at this point.  It's about making users aware of issues. Not hiding them buried inside one single thread.
2016-10-27
oleg_stakhanov
Tahoe Ed Posted at 2016-10-27 19:21
I have confirmed that mine behaves the same way... I was not contacted by DJI. What do you mean working with the users?
2016-10-27
Chaser720
Flight distance : 400190 ft
Fulgerite Posted at 2016-10-28 09:35
We are talking about how erratic stick readings might be related to crashes.  It's HIGHLY relevant  ...
I'm confused. So you're just a random guy in the internet blowing up the issues the Mavic is having or what?
2016-10-27
Fulgerite
Chaser720 Posted at 2016-10-27 21:30
I'm confused. So you're just a random guy in the internet blowing up the issues the Mavic is havin ...
No.  Not really.  I am an experienced DJI owner.  I own P2 and P3.  I have my Mavic on order and I am waiting for it patently.  Meanwhile I am just pointing out some issues that DJI owners and engineers need to pay attention to.  Hopefully get a firmware update out before too many customers experience a crash.
It's all about making the Mavic better...
That's all.
2016-10-28
hallmark007
Chaser720 Posted at 2016-10-28 05:30
I do think it's important that guys who have some experience, get involved, however once it has been taken on board by tech guys here and they report it to appropriate engineers, it will be those guys who will decide if firmwear is needed to rectify problem,
Opinions, photos and videos are all helpful to engineers , so yes the post is important, it does not need to be highlighted on every thread, one thread to discuss if sufficient, otherwise it becomes confusing to newer members. And almost comes across as panicking newer flyers, so I would ask Fulgerite to use one thread for these specific issues.
2016-10-28
12Next >
