mavic pro camera shake shake shake
5791 7 2016-11-7
manhoolee
China
everytime I change the direction,it shakes,flying smooth?it shake also,anyone have the same problem?
2016-11-7
jn005pyKOxC3
I am having a similar problem. Have you checked to see if you are in fpv mode versus follow under the gimbal options?
Also, following shows my problems.
Flight#1 - 1080P, 60fps
Flight#2 - 4K, 30fps
2016-11-7
manhoolee
China
Not in fpv mode, i checked.
I think the problem maybe is the connecter between the camera and the drone is too soft,anyway,it happened almost everytime,so,it maybe a hardware issue. and don't know whether DJI can fix
it with software update.
2016-11-7
Lost Mavic
That looks like motor or prop is out of balance to me.
2016-11-7
CADDJockey
Flight distance : 163934 ft
Looks like artifacts from and image stabilization algorithm - signs of a lot of shaking.
2016-11-7
nils_heidorn
Flight distance : 183537 ft
CADDJockey Posted at 2016-11-8 14:00
Hi !
Did you check if the Gimbal is correctly "locked" in its holding tabs ?
Was mentioned more then once as possible Solution in this forum.
Hope thats it !
Nils
2016-11-8
delsol95
Flight distance : 8186496 ft
Yup, I've seen the vibration and jello everywhere on Youtube.
Check out the video at 1:42.
2016-11-8
fansf911582d
jn005pyKOxC3 Posted at 2016-11-7 19:31
Hey, we have exactly the same problem.
Did you find any solution meanwhile?
2017-3-10
