Choppy Footage
10907 22 2016-11-7
Kuzz
Flight distance : 136900 ft
I noticed in my footage that the video was a little choppy... Anyone know what could be causing this? I was filming at 2.7k 30fps on a SanDisk MicroSD Ultra 64GB - 80MB/s.
I'm quite sure that the footage direct off the Mavic was smooth or atleast smoother. So I'm not sure if it's the rendering of the footage on Premiere Pro?
2016-11-7
JulianX4
Not related to your question, but what are the regulations to fly in Malaysia? Don't you need a license there?
I'll be in Malaysia for a few days in January and am not sure if I should bring the drone or not.
2016-11-7
DJI Natalia
Flight distance : 318 ft
You removed the Gimbal Cover or not? it flied under P mode or S mode? any strong wind when flying?
Would you please upload the original video without editing to dropbox for further evaluation?
2016-11-7
Enkeixpress
Flight distance : 297497 ft
The problem is that you're having the Mavic Pro write Ultra 4K HD content onto a SanDisk Ultra SD Card, or some other SD card. It's not good enough as that's for 1080p HD content, outdated tech. You need a SanDisk Extreme Pro (U3) SD Card for the best possible results. Write speed of up to 100 MB/s.
This one: https://www.sandisk.co.uk/home/m ... epro-microsd-uhs-ii
2016-11-7
Kuzz
JulianX4 Posted at 2016-11-8 15:15
Not related to your question, but what are the regulations to fly in Malaysia? Don't you need a lice ...
I don't live here and it's my first drone so I am unsure. Sorry wish I could be more help. I'm just travelling.
2016-11-8
Kuzz
DJI Natalia Posted at 2016-11-8 15:23
W ...
Yes all gimbal cover and clamp was removed, it was in P mode. Winds were not strong.
I will try get the original footage sorted but I have looked and it doesn't seem choppy to me or at least not where near as choppy as my YouTube video so I would assume this is a Adobe Premiere Pro rendering problem and not the Mavic itself.
2016-11-8
bigglyguy
Flight distance : 14196 ft
Malaysia
Keep away from airports and you should be fine
2016-11-8
Kuzz
Enkeixpress Posted at 2016-11-8 15:30
The problem is that you're having the Mavic Pro write Ultra 4K HD content onto a SanDisk Ultra SD Ca ...
Would this also be fine... I'd rather not spend £100 on a SD card.
https://www.amazon.co.uk/SanDisk ... amp;pf_rd_i=desktop
2016-11-8
4wd
Flight distance : 545817 ft
Kuzz Posted at 2016-11-8 09:20
https://www.amazon.co.uk/SanD ...
More than enough, 4K is not as demanding as writing RAW photo files.
It will be the rendering needs a tweak most likely.
If you have a recent version the 4K youtube presets work quite well.
2016-11-8
Enkeixpress
Kuzz Posted at 2016-11-8 17:20
Yes, that one is fine. It's the same as the one I suggested but lower size, that's all.
2016-11-8
Kuzz
Enkeixpress Posted at 2016-11-8 17:53
No it's not, the one you suggested is a even newer one than the one I posted. It comes with USB adapter instead of SD card adapter and has 200MB/s + speed etc. It costs £98 for the 64GB apposed to this older version that costs £38 for the 64GB.
2016-11-8
Kuzz
4wd Posted at 2016-11-8 17:42
It will be the rendering need ...
OK even though I only filmed at 2.7k 30fps I'm trying to export now at the YouTube 4K setting. See what happens. Will exporting at 4K when only filmed at 2.7K not cause any issues with the quality of the video?
2016-11-8
Enkeixpress
Kuzz Posted at 2016-11-8 17:04
I will try g ...
I use Sony Vegas Pro 14.0 for all of my 4K editing work. I suggest that you do the same. If you do switch to using it, make sure to set pixel format in Files > Properties to 8-bit, otherwise you'll experience lag duing editing.
2016-11-8
cruxiaer
The police just issued a carpet ban on all drones. You will need a permit to fly a drone in Malaysia. Having said that, they are a lot of ways around the authorities in Malaysia. Nothing a couple bucks can't fix.
2016-11-8
Kuzz
Enkeixpress Posted at 2016-11-8 22:21
I use Sony Vegas Pro 14.0 for all of my 4K editing work. I suggest that you do the same. If you do ...
I normally use Sony Vegas for all my editing. It's what I've always used. But I wanted to learn Adobe Premiere Pro. I only have Premiere Pro on my laptop that I'm using whilst travelling anyway so I will maybe continue with Vegas when I return home to my desktop PC.
Thanks for the advice.
2016-11-8
Kuzz
cruxiaer Posted at 2016-11-8 22:25
The police just issued a carpet ban on all drones. You will need a permit to fly a drone in Malays ...
Yes they are corrupt scum bags. I had to pay one off the other day when he pulled me over for no reason. Tried saying my UK license wasn't international. The moron.
2016-11-8
KerryG
Flight distance : 11736709 ft
Looks like one or two things going on here.
1) Shutter speed was very high - we can't fix this until ND filters are available
2) If you shoot at 30fps make sure your timeline is 30fps and not 24fps
2016-11-8
thebmallory
Flight distance : 50466 ft
also use the in-drone format procedure. do not format your sdcard on your computer but do so directly with the drone.
2016-11-8
PROXUS
Your card reading speed is 80mb/s but writing speed might be significantly lower. I have the same issue with the stock card that arrived with Mavic but go wonder ... its U1 Class 10 with 25Mb/s write speed which is not good for 4K video.
2016-11-29
PiperFlyer
I have the same issue with choppy footage in 2.7k at 30fps. It's disappointing. I am using the same micro SD Extreme that I use in my GoPro and get fantastic, smooth 4k footage. It's disappointing. I think the Mavic is a compromise of size vs. camera quality.
2017-1-2
Kuzz
PiperFlyer Posted at 2017-1-2 13:52
I managed to fix mine, was nothing to do with the drone. It was just my rendering in Adobe Premiere Pro, that's all.
2017-1-5
Danny-B-
Flight distance : 306640 ft
Kuzz Posted at 2017-1-5 12:06
What did you do to fix the issue? List your previous then fixed settings.
Just for future ref
2017-1-5
Kuzz
Danny-B- Posted at 2017-1-5 12:18
Just for future ref
All I did was change the sequence settings within Premiere Pro before going to export and render. I changed the Timebase to 30fps. I think it was set to 29.97fps or something random here, so you have to make sure that even if your export settings are correct, you have to make sure the sequence settings are what you need also. Because my export was 30fps but I was still getting choppy footage in the final product because the sequence wasn't 30fps.
2017-1-19
