Charlie Phanto
Flight distance : 102703 ft
Aardvark Posted at 2017-5-20 09:04
The same text files can be extracted for the Phantom 4, note that these are not the .dat files from Assistant 2. There is instruction on that page showing how to download those files from your display device whether it be Android or IOS.
Note: If you're using Litchi, you'll want to select "Litchi" in the listed apps and retrieve the logs from the "flightlogs" folder.
For Android devices:
Connect your device to a computer via a USB cable and go to "DJI/dji.pilot/FlightRecord" (for DJI GO 3) or "DJI/dji.go.v4/FlightRecord" (for DJI GO 4).
Note: If you're using Litchi, you'll find the logs in the "LitchiApp/flightlogs" folder. |
