Osmo Mobile - shutter/record buttons not working ?
15666 15 2016-11-18
NullMind
Flight distance : 119091 ft
I just recently received my osmo mobile and use it with an iPhone 7 plus
I launch the dji app and start the gimbal, it detects it and I am ready to film, but the shutter and record buttons on the osmo don't do anything, sometimes I turned the osmo off and on and they started to work, but most times they don't .. can I be doing something wrong ? Any ideas ?
Carlos
2016-11-18
fans2302c5c0
Im having the same issue. Any joy getting them to work?
2017-2-12
danielsaai
Flight distance : 949459 ft
South Africa
Dis you fix it? I have the same problem!
2017-4-7
malteH
Hi, same thing here, updated to the newest version, everything seems to work - apart from the RECORD button. Any idea anyone? Broken??
2017-4-12
lebronsmomsbf
I had the same issue on my Iphone 7+ I got it to work by pairing it and forgetting this device under my bluetooth settings. The next time I tried to pair it, the phone asked me to accept it like when I first bought it and it worked!
2017-4-19
cleamon
Flight distance : 135564 ft
lebronsmomsbf Posted at 2017-4-19 19:19
Same here with an Android device.  "Forget" the osmo in bluetooth, then reconnect.  Works like a charm.
2018-12-27
send2sergei
Thank you so much for providing this valuable feedback, helped me a bunch got my brand new DJI Osmo Mobile 2 to use with my Apple iPhone 7 Plus and had the same issue. Just got my new toy today and it wasn't quite working right.  Was ready to submit an RMA to get the unit replaced, but then decided to do some searching on the web and stumbled upon this forum. A huge thanks to all of you to providing this resource!
2019-4-4
hepabst
Just bought a Osmo mobile 3 yesterday and having the same problem with record button. I have re-paired the bluetooth but the button is intermittent, I'm using an iPhone 8, IOS 12.4.1. Also updated firmware. is this a product defect?
2019-9-19
djiuser_ZDr8Z4TUrI16
hepabst Posted at 9-19 08:39
I just got the mobile 3 today running it w iphone x and same problem the record button messes w my volume.
2019-9-28
Okay. I was able to fix mine i did it through my filmic pro app, there is an option to use volume switch for record
2019-9-28
fans2bc19f03
Yep.... mine is the same
Intermittent fault in the rec button
Even swapped the unit for a new one and it’s the same problem.
Reloading the software and restarting the unit often brings the function back for a short while and then it fails to work again
Clearly a software issue imo
2019-10-11
Jimbo11249
Same problem using iPhone SE and osmo 3 - rec button wont start recording but does stop it ?
2019-10-22
djiuser_3UNnqz48K576
I had the same issue with the picture/movie start/stop button not working. I read in this forum and learned to lightly touch and release the button.  IT WORKS!
Do not push and hold.  Lightly touch and release!
2019-12-11
djiuser_52vHjrIlbXp3
hepabst Posted at 2019-9-19 08:39
Same.  Just got my Osmo 3.  The record button worked at first, but now it doesn’t work at all.  I’ve updated the firmware.  Using an IPhone 10xs.
Anybody found a fix?
2020-3-18
djiuser_GOH1RVQFmDXb
Same issue, Osmo mobile 2 + iPhone XR, record button not working. Not able to submit bug feedback also last option in that list seems to be disabled.
Tried forget device Bluetooth setting, still no luck.
Any solutions, anybody?
2020-4-23
djiuser 123
Flight distance : 778 ft
Same thing with my Osmo Mobile 3... With Iphone SE 2016.  Mimo and Filmic Pro apps used, 70% clicks on record button just having no response from the phone.
Is it defect of application or device??? DJI Please reply!
2020-10-5
