Mavic focus off?
1227 9 2016-11-20
lhmHL5uSRxuJ
Hi all,
So I've been flying my mavic, but noticed weird focus problems.
The bottom corners of my shots are always out of focus.
So I flew the drone up 100m, and aimed the camera straight down at a pretty much perfectly level field.
If I focus on the centre, most of the shot is in focus apart from bottom corners. If I set focus to bottom corner, everything else is out of focus. Same camera, same position.
Same problem happens on all of my shots!
I  can only imagine that the focus plane is off somewhat. Is there anything I can do to fix this, or is it time to return my 2 day old drone?
Thanks
2016-11-20
lhmHL5uSRxuJ
I have also updated my firmware, calibrated the IMU, and reset camera and gimbel settings
2016-11-20
Kevin16
Flight distance : 353642 ft
Seems to be plenty of misaligned lenses (if that's what it is).  I have the same but towards the top middle, I've heard of others with either left of right being out of focus.  It does spoil a good days shooting.  I've logged a ticket with DJI and am waiting a response.
2016-11-20
lhmHL5uSRxuJ
Kevin16 Posted at 2016-11-20 20:39
Seems to be plenty of misaligned lenses (if that's what it is).  I have the same but towards the top ...
yeah I think it must be a misalignment between then sensor and lens. I can't see it being a software flaw..
2016-11-20
Nees
Flight distance : 80991 ft
Belgium
try this:
I'm skeptical but...
2016-11-20
lhmHL5uSRxuJ
Nees Posted at 2016-11-20 21:07
try this: https://www.youtube.com/watch?v=hYO5Xq-8KTQ
Thanks for the link, but I've already tried that..
2016-11-20
Ange1walk
Flight distance : 30305 ft
Austria
Hi, as bad as this might sound and you probably don't want to hear this, i think you need to RMA your Mavic.
There has been alot of Problems regarding the Lens.
Try this:
Download DJI Assistant 2.
->Reset to Factory Settings.
Calibrate IMU
RESTART Aircraft
Check for Firmware with DJI Go App
and finally Calibrate Gimbal.
2016-11-20
lhmHL5uSRxuJ
Ange1walk Posted at 2016-11-20 21:32
Hi, as bad as this might sound and you probably don't want to hear this, i think you need to RMA you ...
I did all of that (apart from the reset to factory settings).
Yeah I'm reading around now and it seems to unfortunately be a common issue! I'll call my supplier in the morning and send the unit back to them.
I'm hoping I don't have to wait ages to get a replacement..
2016-11-20
DJI Natalia
Flight distance : 318 ft
lhmHL5uSRxuJ Posted at 2016-11-21 06:00
Yeah I'm reading around now and i ...
You have asked your dealer to help you send it back or not? if so, may I know your case number?
If you have not sent it in to them, please help you clarify the aircraft SN, thanks.
2016-11-23
icarusknows
Flight distance : 3166 ft
I had the same issue and RMA'ed my Mavic with DJI North America.  Should be receiving it back next Monday.
Here's a link to my experience, FYI:
http://forum.dji.com/thread-72586-1-1.html
...Also the video posted above is completely unrelated to this issue.
2016-11-23
