Gimble Yaw Wander
1403 13 2016-11-20
BradC234
Flight distance : 219770 ft
Hi,
It seems when my Mavic is placed on the ground, the yaw direction of the gimble is slowly paning in the yaw direction, anyone see this?
2016-11-20
Nees
Flight distance : 80991 ft
Belgium
You mean tilting? Might be your surface is not level.
2016-11-20
BradC234
Nees Posted at 2016-11-20 22:11
I dont think so, i am on my kitchen table which is pretty level. The gimble is moving left to right.
2016-11-20
Visual Air
Flight distance : 2710115 ft
It will if your moving the yaw or rudder stick thats normal..
2016-11-20
BradC234
Visual Air Posted at 2016-11-20 22:55
I havent even taken off or even touched any controls. It just goes by itself, almost like the ginble is still trying to initialize.
2016-11-20
Nees
Belgium
Make a video... Easier to understand
2016-11-20
BradC234
Nees Posted at 2016-11-20 23:07
Il have to do that tomorrow
2016-11-20
BradC234 Posted at 2016-11-21 12:08
Have you tried to do the gimbal calibration?
Before the gimbal calibration, you could do the IMU calibration on a completely flat surface first.
2016-11-20
BradC234
DJI Mindy Posted at 2016-11-20 23:29
Before the gimbal calibration, you could do the IMU c ...
I tried the IMU calibration and several gimble calibrarions all of which seem to yeild the same results. Would a compass calibration effect the gimble in anyway? Or just the IMU?
2016-11-20
CamStevens
I've seen the same thing happening on my Mavic during warmup.  I thought perhaps it was because the IMU was still warming up.  It eventually settles down for me.  That being said, I do find that I have to calibrate my Gimbal every couple of power cycles.
2016-11-20
BradC234
CamStevens Posted at 2016-11-20 23:35
I've seen the same thing happening on my Mavic during warmup.  I thought perhaps it was because the  ...
Atleast Im not the only one! Do you find that regardless of the gimble pitch you align to before flight you still have to adjust it to the horizon mid flight as well?
2016-11-20
JFXMedia
I have seen it numerous times on mine, especially while flying. It's like a slow steady pan to either side usually left, as if the angle of the camera is steering the drone, so the drone does indeed fly to whatever side the camera is yawing. It also happens on the ground for me or just hovering
2016-11-21
CamStevens
BradC234 Posted at 2016-11-20 20:39
Atleast Im not the only one! Do you find that regardless of the gimble pitch you align to before f ...
So far, no, I have not seen that.  Once I have adjusted the gimbal roll, it seems to stay put.
2016-11-21
BradC234
JFXMedia Posted at 2016-11-21 10:39
I have seen it numerous times on mine, especially while flying. It's like a slow steady pan to eithe ...
Such a pain! I wonder if there is a solution to this?
2016-11-21
