DJI-Jamie
Flight distance : 112405 ft
For the P4, I believe that it's built into the center board since you can use the basic waypoint option without any extra components for autonomous flight. At the present time the A3 needed LB2 in order to perform the waypoint function, which meant that it was already hardware dependent. Ground Station will be more advanced than 'waypoints' and needs the beefier hardware for more intricate work. I'm not participating in the P4 Ground Station BETA testing myself, but I would speculate that it's not going to have the exact same functionality as the Pro System rigs.
Just to provide some parallel, the P2 was able to use the old PC Ground Station but it did not nearly have the same functionality as when the program was used with and A2 or a WKM. It didn't have access to photogrammetry or some of the other intricate options that it offered. |
