Phantom 4 Pro - HDMI module compatible?
4754 14 2016-11-30
Andy Sayle
Flight distance : 3358875 ft
Hi Folks,
I received a P4Pro today, and all is good.  I ordered the basic set without the display (so I can still use my little samsung tablet/ipad).  The TX doesn't have a HDMI output on it anywhere.
Does anyone know if the Phantom 4 HDMI module upgrade (Spare part 54 according to the label on the box of mine) is compatible with the P4Pro transmitter?
Cheers
Andy
2016-11-30
DJI Natalia
Flight distance : 318 ft
Andy, the HDMI module for Phantom 4 can be used for Phantom 4 Pro.
2016-12-1
ZOMBEE
The HDMI module does not work on the P4P.  The latest firmware update did nothing for me.
2016-12-14
Velocity35
I can also confirm the HDMI module does NOT work on the P4P remote controller. You can install the HDMI module with no issues (ribbons still connect in same places they should into the board) but when powering on the remote controller, I get a red dot and Disconnected in the App itself.
2016-12-14
DJI-Jamie
Flight distance : 112405 ft
Velocity35 Posted at 2016-12-15 12:53
The P4P RC is awaiting a firmware update in order to support the HDMI module.
2016-12-14
Velocity35
Great! thank you DJI-Jamie.
2016-12-16
SIAPV
Hello , for the time mine don't work :-( When I plug the HDMI cable on the external screen  the smarthphone (Android) can't give video .
I have only OSD (ON or OFF) but no video signal :-(
I hope next firmware update is coming soon !
2016-12-16
mikesher.live
Flight distance : 123045 ft
ZOMBEE Posted at 2016-12-15 05:14
Don't give up.  It works for me (iOS and Android).  I had to re-update the firmware on the remote (as prompted from iOS).  Also check cable connections.   Proof is in the pictures: Pictures of P4P w/HDMI module
2016-12-16
SIAPV
mikesher.live Posted at 2016-12-16 23:17
How you do for re-update the RC firmware ? (Android) ??
2016-12-17
mikesher.live
SIAPV Posted at 2016-12-18 04:13
I ended up using the iOS app, as it prompted me to upgrade.  The Android app did not prompt me to do the upgrade.  I am not sure what the process is to revert to a previous firmware on the remote, and then re-upgrade but that is definitely what is needed. Now that my firmware on the remote was upgraded AFTER installing the HDMI module, it works on both iOS and Android.   When I first installed the HDMI module AFTER my 1st remote firmware update, it did not work.  It was only after re-installing the firmware that it started working.
EDIT:  I found this topic elswhere on the forum to downgrade the firmware: http://forum.dji.com/thread-48287-1-1.html
2016-12-17
SIAPV
mikesher.live Posted at 2016-12-17 22:09
Thanks for your answer ! The RC is now updating (in progess ... ) :-)
I forgot one touch (update required Tab) for the RC ...
2016-12-17
WHGP34K
Flight distance : 14918 ft
DJI-Jamie Posted at 2016-12-14 21:49
I just got my new Phantom 3 4K, found no HDMI output on W325 controller. Can I purchase and install the HDMI Module on the P3 4K? The challenge for me today is do I keep it, or send it back. The HDMI output is critical to me.
2017-8-12
yosephat
Flight distance : 724570 ft
Indonesia
DJI Natalia Posted at 2016-12-1 01:13
hello, Natalia.
Can I use phantom 3 Pro/Adv HDMI module for phantom 4 Pro RC without display?
2018-1-7
TheMann58
Flight distance : 18669501 ft
Yes - I have installed HDMI modules on my P3 Pro, P4 and P4 Pro RCs and it works on all three. You MUST update/refresh the RC firmware to install the required drivers for the HDMI module and then it will work.
2018-1-7
miguelss188
Mexico
Hi everybody! I have a Phantom 4, no adv, no pro, only Phantom 4 with the last firmwares in RC and Drone. I have been trying to use HDMI module, but i get weak transmissionsignal, the cause is HDMI module. In other post people says the problem is fixed with a downgrade, somebody knows what firmware in RC and drone? I use DJI GO 4 v4.2.20 in Samsung Galaxy S5 and v4.2.16 in iPad Air 2. Sorry for my english.
2018-7-12
