Mavic drifting (yaw)
3019 14 2016-12-5
VoxUltrasonic
Flight distance : 328602 ft
After receiving my Fly M ore combo about a week ago, I finally caught some good weather to take the Mavic out for some flights. I noticed a couple issues:
-When ascending immediately after takeoff, I noticed that the Mavic doesn't perfectly hold it altitude for a moment. (For example, I will ascend to 5m, and it will very slowly descend on its own (sticks neutral). If I fly up and down a little bit it seems to "shake out" and starts to hold itself better. Not a huge issue, but calling it out in case it's a symptom of something worse.
-When I'm up in the air hovering, taking some time-lapse video or taking photos, I noticed that the Mavic will drift slightly, turning very slowly counter clockwise. It's slow enough that on my small iPhone 7 screen if you're not paying attention its easy to miss, but if you look closely it's quite obvious. This is a concern to be because I've heard great things about Mavic's low light performance and wanted to try out some longer exposures. Unfortunately when I did, I was having a really hard time taking anything that didn't look blurry (even after focusing)
Anyone else run into this issue?
2016-12-5
TechShizzle
Flight distance : 273730 ft
I've have the same issue with yaw. Going forward it will rotate counter-clockwise and slowly veer to the left.
2016-12-5
Hi VoxUltrasonic, could you please post some videos of the drifting issue?
As for the image, please upload the original images to dropbox and send me the link.
I'll help to check it.
2016-12-6
andersonn
I've also experienced the slight drifting issue, sticks were calibrated also and same thing.
2016-12-6
VoxUltrasonic
DJI Mindy Posted at 2016-12-6 01:11
Hi Mindy,
I finally was able to take advantage of some decent weather to record these clips (it's been raining and snowing a lot in my area, preventing me from flying):
It seems I almost always have a slight drifting in the yaw, which prevents me from taking clear long-exposures (1-2 seconds). Is this normal? I've read that Mavic is REALLY stable for most people, especially when taking long exposures.
2016-12-13
RoyEP3
Flight distance : 286017 ft
I'm having the same yaw drifting issue.  Were you ever able to fix this?
2017-1-9
stratosHD
Flight distance : 1231280 ft
Yes yes!  I noticed the same also, specially rolling a bit to the right side clockwise. I have calibrated everything that can be calibrated and still feel that there is a small drift specially on initial take off. Now, I never take off without proper GPS signal 10+ satellites and never fly at night / low light.  So I wonder if there is something else I can do to correct the small drift.
2017-1-9
stratosHD
VoxUltrasonic Posted at 2016-12-13 11:25
Hi Mindy,
This is exactly what happens with mine. Thanks for the vids.
2017-1-9
VoxUltrasonic
I wasn't able to get to the bottom of it, but my Mavic had some other issues and is currently on its way to DJI for assessment for replacement.
I'm looking forward to getting one back in my hands!
2017-1-10
bantis
I am seeing the same thing. It never happened when I first got it. Seemed after one of the updates that it started to do it.
2017-1-10
xanthos84
Flight distance : 253845 ft
Austria
same here.
please DJI - we need feedback on this!
2017-1-11
Brutus
Flight distance : 124304 ft
Mine is yawing clockwise sometimes, only just after take of. I've only noticed it when I was flying outside, never experienced it flying inside my living room.
2017-1-11
RoyEP3
Brutus Posted at 2017-1-11 02:45
Mine are the exact same conditions.  Only occurs after take off.  Can't replicate the problem inside my house.
2017-1-11
Shoruk3n
Flight distance : 414501 ft
Same here.  Tried calibration of IMU, compass, and rc st
icks but still have the issue.
2017-1-11
tyler947
Flight distance : 3878802 ft
I'm still dealing with the same issue dollowing IMU calibration (cold) on a level surface, RC calibration, factory reset, compass calibrations etc. I was hoping the .800 firmware might help.
2017-6-11
