No update to 2016.12.9, error 0x020103
3956 21 2016-12-9
fans6dbda3e6
[ Last edited by Sauerländer In 2016-12-9 21:47 Editor ]\n\n[ Last edited by Sauerländer In 2016-12-9 21:46 Editor ]\n\n[ Last edited by Sauerländer In 2016-12-9 21:45 Editor ]\n\nHi guys,
trying to update my P4P and it gets stuck with error 0x020103 in the UI.
Watched two more failed update processes on the terminal. From what I can see the upgrade fails because the update of  Lb_dm3xx_sky(1) seems noot to work.
Any ideas how to workaround that / what the reason might be?
Kind regards,
Dan
[Api-Controller      ] Assistant Unlock: 0
[DynamicTableCommonIm] Table: 0, Size: 45   , Hash: 58ae2100, CmdId: 3e50
[DJIDynamicCommandTab] Cmd Table Size: 99   , Hash: 12345678
[DJIDynamicTable     ] Board:      Controller(0): wm330v2   , 3.2.12.47
[DynamicTableCommonIm] Table: 1, Size: 60   , Hash: 58b1b400, CmdId: 3e50
[DynamicTableCommonIm] Table: 0, Size: 321  , Hash: d671872f, CmdId: 3e00
[DynamicTableCommonIm] Table: 1, Size: 722  , Hash: 18cfa86a, CmdId: 3e00
[DJIDynamicTableManag]   1%
[DJIDynamicTableManag]   2%
[DJIDynamicTableManag]   3%
[DJIDynamicTableManag]   4%
[DJIDynamicTableManag]   5%
[DJIDynamicTableManag]   6%
[DJIDynamicTableManag]   7%
[DJIDynamicTableManag]   8%
[DJIDynamicTableManag]   9%
[DJIDynamicTableManag]  10%
[DJIDynamicTableManag]  95%
[DJIDynamicTableManag]  96%
[DJIDynamicTableManag]  97%
[DJIDynamicTableManag]  98%
[DJIDynamicTableManag]  99%
[DJIDynamicTableManag] 100%
[DJIDynamicTable     ] [......meterTable]      Controller(0), load from file: Template v3.2.7.0.cfg
[DJIDynamicTable     ] [.......DataTable]      Controller(0), load from file: Template v3.2.7.0.cfg
[DJIDynamicTable     ] [........andTable]      Controller(0), load from file: Template v3.2.7.0.cfg
[DJIDynamicCommandTab] var mapping: 66 , switch_to_sd_card                    => enter_sd_card_mode
[DJIDynamicTableManag] dyn_mgr read: true, TIME: 3801(ms).
[consisUpgrade1860   ] ======================= UPGRADE FAILURE: push upgrade failed status
[UpgradeMgr          ] enable_upgrading_flag: false
[upgrade1860Ex       ] ======================= UPGRADE FAILURE: push upgrade failed status, error code: 0x020103
[upgrade1860Ex       ] ======================= Time : 1481312861.50 second
[UpgradeMgr          ]    Lb_dm3xx_sky(1) result false
[UpgradeMgr          ] upgrade_pack_file_data time used: 85.857 Second
2016-12-9
DJI Natalia
Flight distance : 318 ft
For this error, we need put in another file into the root of SD card and upgrade it again, may I know your e-mail address and we could send the file and upgrading instruction to you.
Or you could get in touch with our support via support@dji.com if convenient.
2016-12-10
Sauerländer
DJI Natalia Posted at 2016-12-10 09:11
Or you could get in touch with our support via  if convenient.
Thanks for the quick reply, I sent you my email address via direct message.
2016-12-10
DJI Natalia
Sauerländer Posted at 2016-12-10 17:09
I refreshed the page, unfortunately, I did not receive your message for some reason.
I tried to PM you, please check whether you can get it. If no, then please post your e-mail here, and I'll hide it once I get it.
2016-12-10
Sauerländer
DJI Natalia Posted at 2016-12-10 10:17
Also received no PM.
You can send it to *******
Thanks in advance.
2016-12-10
DJI Natalia
Sauerländer Posted at 2016-12-10 17:23
Great, please check your e-mail box later, our support will send you the instruction and file. Please keep us posted with the results.
2016-12-10
Sauerländer
DJI Natalia Posted at 2016-12-10 10:29
Upgraded the Firmware file and afterwards the update to 01.01.0203 worked, thanks a lot!
2016-12-10
DJI Natalia
Sauerländer Posted at 2016-12-10 18:27
No problem, glad to hear it's upgraded successfully, hope you enjoy your flight!
2016-12-10
hannsalazars
Mexico
can you send me the file i hjave that problem too try to update by cellphone and by assistant but no luck
thanks
hannsalazar@gmail.com
2016-12-10
fans07defe50
Mexico
DJI Natalia Posted at 2016-12-10 00:11
Hey, i have the same problem my e-mail is fgayol91@gmail.com.
2017-4-27
DJI Natalia
fans07defe50 Posted at 2017-4-27 22:35
Hey, i have the same problem my e-mail is .
Please check your e-mail box with the file to upgrade P4P again as the instruction, hope it works.
2017-4-29
暖二狗
China
DJI Natalia Posted at 2016-12-10 02:39
Hi, can you send me the file?
I try to update my Mavic and it seems have the same problem.
My e-mail is rikanjyo@outlook.com
Thanks!
2017-4-29
DJI Natalia
暖二狗 Posted at 2017-4-29 23:49
My e-mail is
Sorry, this bin file is for phantom 4 Pro but not Mavic.
You tried to upgrade it through both DJI GO and Assistant 2 but failed, right?
What percentage it stops?
2017-4-30
暖二狗
China
DJI Natalia Posted at 2017-4-30 02:17
**** The posts are shielded ****
Yes, both failed.
Use DJI GO 4, stopped at 92%
[2017-04-28 23:36:03.037]push upgrade progress: 90%
[2017-04-28 23:36:03.304]upgrade fail reason: 2
[2017-04-28 23:36:03.304]upgrade state 11
[2017-04-28 23:36:03.314]sub module info: modueID: 0x01, firmwareVersion: 00.00.00.00, state:Upgrade error. (code 3), progress: 99%
[2017-04-29 15:23:41.537]sub module info: modueID: 0x01, firmwareVersion: 02.06.04.84, state:Firmware Error. (code 6), progress: 0%
And
[2017-04-29 15:23:41.537]upgrade progress 68%
[2017-04-29 15:23:42.995]upgrade fail reason: 2
[2017-04-29 15:23:42.995]upgrade state 11
[2017-04-29 15:23:42.995]Start download aircraft upgrade log
[2017-04-29 15:23:43.007]sub module info: modueID: 0x01, firmwareVersion: 02.06.04.84, state:Firmware Error. (code 6), progress: 99%
Use Assistant 2, failed at 60%, and the log is the same as 1#'s.
2017-5-1
DJI Natalia
暖二狗 Posted at 2017-5-1 06:46
Yes, both failed.
Have you tried to upload error log when it failed to upgrade? if so, what is your dji account (e-mail)?
Would you please export the upgrading log through DJI assistant 2?
The tutorial below is for your reference, then please upload it to Dropbox and post the link here, I will forward it to the engineers to check the log.
2017-5-2
gfab71
Flight distance : 492874 ft
Can the DJI engineers please make a similar 'patch' to upgrade Mavic Pro that are not upgrading ?
Hope to resolve finally the fw upgrade problem, the error that shows DJI GO4 app is the same.
2017-5-9
gfab71
This is the error after the message of upgrade fail
2017-5-9
DJI Natalia
gfab71 Posted at 2017-5-9 11:54
Could you please provide me your DJI account? we'll reconfigure it for you.
Then you can upgrade it through Assistant 2 directly, the upgrading method is the same as before.
Here is the instruction:
1. Upgrade the firmware V01.03.0350.
2. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to V01.03.0600, it will be working.
2017-5-10
gfab71
DJI Natalia Posted at 2017-5-10 02:48
But via DJI Assistant 2 once i tried to upgrade, has failed... my Mavic is currently running 01.03.400, how can i UPgrade to 01.03.350 .. ?
2017-5-10
Clara B
Hi
i have the same problem.
can you please send me the files and configure my account?
i sent it via pm
2017-5-21
DJI Natalia
Clara B Posted at 2017-5-21 00:28
Hi
I received your message, will help you reconfigure it on Monday, please try to upgrade it tomorrow, hope it works!
2017-5-21
dan75248
DJI Natalia Posted at 2017-5-21 00:54
DJI Go 4 just crashed while I was updating my Phantom 4 controller firmware while using an Android device.  I attempted to reopen the app, but it now says I'm using an Inspire 1 and to download DJI Go instead.  Again, this is a Phantom 4 and I'm stuck.  I need this for a project tomorrow.  I hope someone can help.
2017-10-11
